Which Gen of 911 is Easiest to Wrench?
Old 05-02-2018, 09:36 PM
porscheconvert
porscheconvert's Avatar
Default Which Gen of 911 is Easiest to Wrench?
Contemplating a project car...and doing my best to immerse myself into understanding scope and skill set required to rehab a car. For those that have owned many generations, do you have perspective on which generations would be better candidates for someone that doesn't have a mechanical background?
As example, seems like dropping engine on SC is not really that invasive. Thoughts?
Old 05-02-2018, 09:40 PM
ADias
ADias's Avatar
Old 05-02-2018, 09:49 PM
linderpat
linderpat's Avatar
Received 2,250 Likes on 1,254 Posts
I'd go even further back and say the 356 pre A! All kidding aside, and assuming you have some kind of budget restraint, it will be one of the air cooled gen cars, and the best deals are the mid-80s vintage. A 996 isn't all that bad either, and you can get them quite cheap, allowing lots of room to work on it and do what you want with it.
Old 05-02-2018, 11:25 PM
Marv
Marv's Avatar
My 1/64th scale Gen I 996 GT3 Die-Cast Model.
Old 05-03-2018, 01:24 AM
porscheconvert
Thanks, Linderpat. If you had basic mechanical foundation, what steps would you take for going a bit deeper? I want to plan first, then buy.
Old 05-03-2018, 01:29 AM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,246 Likes on 782 Posts
I’d vote for the 996 in the water-cooled cars.
Old 05-03-2018, 01:31 AM
ADias
ADias's Avatar
If not a 901... yeah, in an SC or on a 3.2 there's a lot that a reasonably skilled owner can do.
Old 05-03-2018, 01:41 AM
porscheconvert
996 is out as I have a 997.
Old 05-03-2018, 10:11 AM
sloanfiske
5th Gear
sloanfiske's Avatar
Anything before the 964?
Old 05-03-2018, 10:13 AM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,417 Likes on 859 Posts
The easiest one is the one where you have access to the most/best information.... and a great set of tools.
Peace
Bruce in Philly
Old 05-03-2018, 10:46 AM
Meursault88
Meursault88's Avatar
Any version that a Haynes manual exists for. I did a 901 but would not do it again. The quality of the metal just isn't that good. Like many, I spent a lot more time restoring the car than I ever did enjoying it.
Old 05-03-2018, 12:32 PM
porscheconvert
thanks! Exactly kind of data I'm looking for here. I wouldn't say I'm interested in full restoration...more simple rehab on the maturity curve.
Old 05-03-2018, 12:46 PM
Ben Z
Ben Z's Avatar
If by not having a mechanical background you mean you have no experience beyond the rudimentary, and by rehab you mean restoration, then frankly I would get my feet wet with something like an 80s Mustang where a project car and the parts are cheap and plentiful. The cost of buying any project Porsche, plus the parts, is rather expensive if you mess anything up. But if that doesn't faze you then I would suggest as others have, a 911 from the 80s. But beware of rust. Mechanical work can be learned on the fly, but fabrication, welding, and bodywork including paint-prep are things it takes a lot of practice and experience to get good at. I've done frame-off restos, and believe me those shows on Velocity make it look a LOT easier than it is!
Old 05-03-2018, 03:00 PM
OnlineAlias
OnlineAlias's Avatar
996's and 7's are so similar from a repair-ability perspective it doesn't really matter. They are all very, very easy to work on.
I've owned over 80 cars and I worked on all of them myself, for the most part. A 911 is crazy easy when compared to something like a BMW of the equivalent year. Porsche doesn't have to over complicate the engineering by re-inventing everything to impress with the latest features on things that don't matter. (heads up display? Nope. Power steering column? Nope. Keyless go? Nada.) In this way, a 911 is somewhat unique in the marketplace.
Look at the windshield wipers on a 997, for example. Same arms and configuration they've been using on VW/Porsche/Audi since the late 70's. Now look at the ones on any modern Mercedes. Just replacing the blades is a PITA.
Old 05-03-2018, 03:06 PM
Doug H
Doug H's Avatar
S.C., 3.2 and 964s are super to work on and generally easy to get parts for.
Quick Reply: Which Gen of 911 is Easiest to Wrench?
