Brake Caliper Question
One for the brain trust - just swapped in my track pads this weekend, my first time working on the brakes on this car. I bedded them in properly.
This morning, after driving to work (damn they squeal like stuck pigs), I looked at the calipers all the way around just to triple check status. I noticed something I had not noticed before. As you can see in the picture, there appears to be a steel dowel extending perpendicular from the caliper face towards the rotor face. There are two dowels per each side of the caliper, and obviously the pads nest on them. But if you look at the picture, you can see that the pad doesn't have to wear down very far before those steel dowels will start to grind into the rotors.
What am I missing here? Do those dowels automatically retract as the pads wear down? If not, then you do not get much pad wear before you run into real trouble. Any thoughts appreciated.
Just another thought re the above - the pistons extend as the pads wear, pushing the back of the pad forward toward the rotor face, so presumably, the pad wear never reaches the face of the dowel. Am I close?
Dowels keep the pads in place. Remove them and out pop your pads.
You should have used new PA's dampeners or st least anti-squeal paste on the backs of the pads when installing to keep them from squealing.
Basic Site Sponsor
Basic Site Sponsor
*Coming soon high temperature dust boots and piston seals!
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
And yes they are and they sure do. The street pads with new dampeners all going back in immediately after Watkins Glen in early May.
Squeal
A liberal amount of anti squeal paste on back of pads and retaining pin will eliminate the squealing 100%. Be sure not to get the paste on rotor or front brake pad material. Anti vibration damper pads/pucks are a PAI as they may rust into place especially in northern areas with heavy snow and rainy climates where salt is used on roads. I'd advise on taking out damper pucks if they're not stuck yet and just using the paste.
good luck
good luck
good luck
good luck
mie
I found I could help modulate the squeal on the street by braking a bit harder earlier (when they are quiet) and easing up on the pedal as I came to a stop - when the squealing is at it's worst. If you hold the pedal hard all the way to stop they will scream!
Yup, altho I love watching the faces of those nearby in traffic when I do that. The bite is awesome with these pads
Fyi, bedding in track pads, then running around the streets with them in for almost a month negates the bedding in process of transferring a layer of pad material onto the rotor. Not to mention its harsh on your rotors running track pads on the street for that long. Peeps run track pads on the streets a couple of days AFTER a track weekend to clean off the pad deposits built up on the rotor from the extreme heat created at the track. Read this and what I'm saying will make more sense: https://www.zeckhausen.com/catalog/i...Path=6446_6444
