Exhaust Tips
Exhaust Tips
Hi all,
How do you remove the tips from a 2005 Carrera base model.
I've tried to loosen the nut under the tip but any way I turn it stops as if tightening. I used wd40 on it earlier and the nut still binds up.
I'm working on the floor so my access isn't that good. I had it loose but couldn't get it off the pipe.
Any suggestions would be appreciated.
Mitch
2005, 3.6, oval tips, no mods.
Mitch
Hi all,
Mitch
Mitch
Use 13mm socket and remove this bolt completely.
This flange needs to be loosened / widened to get tips off.
I used a small slotted screw driver where the bolt was sitting to widen the flange.
About 1/4 inch should do.
Good Luck
loosen the nut all the way get a flat head and a small hammer.. go around hitting it with hammer till it pops out...
all the years of rust build up make it hard to come out..thats what i did on mines
Before
After
They did a fantastic job..$90. Now I just have to wait for a warmer day to put back on, and all the snow to disappear...been a long winter here can't wait to get the little black car out!
also, use PB Blaster or even liquid wrench; WD-40 is the least effective penetrant for stuck hardware. Also, let the penetrant soak in good and long before trying to remove the nut.
http://nitroplate.com/news/coatings-...amic-coatings/
Shaymus
Thanks Blaine997 they look great.
Shaymus, I'll read the article, thanks for your input on this. I'll post some pictures as soon as they come back.
