DIY Brake fluid change
Quick question,
I have a 2006 Carrera S that obviously has PASM. I read somewhere you need to use a Porsche maintenance computer program to cycle
the valves when doing the brake flush.
Is this all BS, is it a complete DIY project with a brakeflusher and no computer hooked up.
Cycling the ABS pump just allows you to get that fluid that is in there out. Its not necessary. You'll be replacing 90% of the fluid anyways. If you were nuts about it you could do a gravity bleed and then go out and panic stop the crap out of the car and then do another gravity bleed. Its not a lot of fluid anyways but I wouldnt bother. I'd just gravity bleed it and be done.
BTW.... you DO NOT want to introduce air into the system. If you get air in the system you may have to cycle the pump to get it out. You can technically do that too by panic stopping the car but you should have a very safe PRIVATE area to do this if you go that route. If you do a gravity bleed and never run the MC dry you'll be fine.
I used a turkey baster and remove the fluid in the reservoir. Then I put .5L or so of new fluid in. Then I gravity bleed .25L or so from each caliper while adding more fluid in and its an easy job. If you get inpatient and try and dump all the fluid out at once or pump the pedal aggressively youll get air in there.
Mike
Mike
Mike
BTW, Durametirc won't pump your ABS regardless of what they claim. Yes, the ABS fluid stays and that was the reason people thought in the old days the Super Blue stains their brake system. Actually it was the old Super Blue left in the ABS that got dumped (when activated) into the rest of the brake system causing people to think that the Super Blue stains the system. I still alternate using the Blue and Ember colored fluids. The Blues are still available through mail order from UK, but very expensive compared to the ember.
I figured it doesnt do coding even though it does say...
- Performs special functions, coding, security access**
Anyone feel like sending them an email?
Mike
Interesting....
I just got off the phone with ECS and the guy has this same NT510 for his chevy and his VW and he reports it actually does to coding BUT they offer not support or guarantees on it because they dont want to be responsible for people bricking a module.
You can also pay for upgrades for other car manufacturers and load as many as you want on this device which is awesome. I'm going to keep doing more digging and try to get someone at foxwell to get more info but I may pull the trigger.
Mike
Mike
Interesting....
Mike
Mike
wow, that’s pretty cool! I already have a Durametric professional version, but haven’t stumped up the cash for a Mercedes Star diagnostics, and that has a whole heal of multiplexers plus you need a laptop. If I could get the Mercedes version and then possibly buy a Porsche module, that would kick butt.
mike
Ive also hear the durametric wont get the ABS pump to cycle. If I every get around to it I'm going to order this then...
https://www.ecstuning.com/b-schwaben...656sch01a~scf/
Mike
Mike
My Durametric Pro absolutely can cycle the ABS pump in the Brakes Activations menu on my 2005.. I had to do it when I accidentally ran the reservoir dry when doing a Motive pressure bleed using the dry method. Since then I've switched all my cars over to the same Motul RBF600 and now just fill the plower bleeder up once a year and do all the cars one after the other, then clean it up until the next use - usually next year.
