DIY Brake fluid change
Old 04-15-2018, 12:26 AM
  #31
Saaboteur
Saaboteur's Avatar
Mike, where are you buying the tool for $150? I’d like to get one with both Merc and Porsche software loaded. It’s be nice to keep in either car if on a road trip, as opposed to lugging the Durametric around (and Mercedes DAS is even bulkier).
Old 04-15-2018, 12:32 AM
  #32
bhvrdr
bhvrdr's Avatar
Here ya go brother
http://m.foxwelltool.com/wholesale/n...e-and-obd.html
Old 04-15-2018, 01:26 AM
  #33
Saaboteur
Saaboteur's Avatar
Thanks brudah!
looks like I need to get the 520 at least. Then I can get coverage for basically all of the cars in our fleet! Benz, Saab, Land Rover and Porsche!
Old 04-16-2018, 03:50 PM
  #34
GoatFarmer
GoatFarmer's Avatar
I can also confirm the Durametric will activate the ABS pump on a 997.1 GT3. I boiled fluid at the track once and needed to activate the ABS pump using the Durametric software to restore normal pedal pressure. A standard 2 man bleed did not do the trick.
Quick Reply: DIY Brake fluid change
