Programming clutch interlock out from DME
5th Gear
For some reason clutch interlock is preventing car from starting. Sensor is fine and I have also tried to bridge the connectors, but still the "depress clutch" is on and preventing the car to start. Could it be programmed out of DME? Or any other ideas what or where to check. I have checked through the fusebox on drivers side and its all fine. Perhaps there is some other fuse to be checked? Have been trying to find out from the electric schematic but no success so far. Car is 2005 997C2S. Thanks.
Instructions attached
