Lowering springs for 997.2
#31
Man of Many Porsches
Thanks for the help on this thread, I went with Techart which is Eibach and 15mmrear/7mm front spacers...... ive tried HR,Voghtland, pss9, X73,X74, and ROW in that past..lol.... The ride is so good very compliant..
Im thinking of replacing the wheels with CHR Porsche fitment from Tirerack... anyone have that setup? its wider than stock same offset.. prob wont need spacers anymore..
Spacer in the front needs another 5mm...lol
#32
pascalemod (07-27-2023)
#33
#36
I have Eibach springs on my C4GTS and actually don't care for the ride height. The ride is as good as the factory springs but I wish it lowered the rear of the car more. The front is pretty good, when I get coil overs, which is whole different issue, I don't think I would drop the front much if at all. These cars have an issue with nose clearance from my experience the last 3 years.
#37
My GTS had Eibachs when I bought it but I switched to H&R for the exact same reason you state. The fronts don't seem to change much between the two brands (a tad lower on the H&R's) but the rears drop an additional .25" with the H&R's which doesn't sound like much but makes all the difference. Since your car is a GTS, chances are you've got CL wheels. The more you drop it the more tucked into the wheel well look you'll get. With CL wheels, the only fix is to buy after market wheels with custom offsets. No spacers allowed with CL wheels so you can fix the ride height fairly inexpensively but to complete the stance with the wheels flush with the fenders turns into a whole different story. No difference in ride quality between the two brands btw., at least not to my senses.
For the drop between the brands, I've always read the drop numbers as 1" even both front and back for Eibach/Techart and 1.25" front and back for the H&R's. Now I'm seeing different numbers but no question, no matter where you look, the H&R drop is lower than Eibach/Techart. I've attached a picture of my current GTS rear wheel with H&R for your reference. Worth pointing out is that the wheels have custom offsets since again, spacers are not an option on CL wheels.
#38
Disregard and stop wasting time right here if you're getting coilovers except for the part about spacers/wheels flush with the fenders.
#39
I do have cl wheels but I purchased bbs re mtsp wheels about a year ago. My rennlist account expired due to negligence and now I can’t post pictures lol. I should’ve gone with H&R springs but I had a less than stellar experience with them on my S4. My car is an AWD GTS so I’m not sure if there is a difference in the ride height for those springs??? Anyway, I’ve been working on my RS4 instead lately so p car changes are on indefinite hold.
#40
I have H&R lowered springs with BBS CHR on my CarreraS and love the look. I am using the 5mm spacers all around and the offset is perfect.
Enjoy,
-skip
Enjoy,
-skip
#41
I'm runnng the H+R lowering springs because of the ride height, and I certainly don't think they're all that stiff. I did however add the TPC Racing DSC module, which improved ride quality and body control.
As far as I could make out, the TechArt springs are made by Eibach to their own spefication (hence the higher price). Both Eibach and H+R have good reputations (I've used other parts from H+R) but a friend of mine suffered from a broken Eibach spring on another car, so I decided to stay away from Eibach. Whether the internet agrees of course is another thing completely. But I'm happy.
#42
I find the ride height with Eibach springs quite pleasing, but to each their own I guess. Here is my Targa 4 before and after (no pasm).
OEM springs
Eibach springs
OEM springs
Eibach springs
DesmoSD (03-18-2021)
#43
So after installing the lowering springs the only thing needed is an alignment. Is that correct?
#44
Thanks! You can buy the side decal from here (no affiliation):
http://www.designstuffonline.co.uk/v...97_decals.html
The shipping takes a little while (2-3 weeks) but the quality is great.
I really like the stripe and I want to add one. However my car is Aqua Blue. What are thoughts on just black? I think white is too much of a contrast
