Replacing 997.1 clutch slave cylinder
Old 02-10-2018, 07:44 PM
Garker
Garker's Avatar
Default Replacing 997.1 clutch slave cylinder
I need some suggestions/help. I am trying to replace my slave cylinder while the transmission is in the car. The car is on a lift. If you have done this, you know the holes for the two mounting bolts for the slave cylinder are not visible (at least they weren’t to me). We had a very difficult time, but finally got the bolts secured only to discover the end of the slave was not properly seated on the clutch arm. We found out when the clutch pedal was pushed and the piston blew out of cylinder followed by the brake fluid. So it all came off again. I am aware that this works best if the bleeder valve is open so that the piston can be pushed.
So am I missing something? Is there any easier way.
Thanks,
Lin
Old 02-10-2018, 11:53 PM
TheBruce
TheBruce's Avatar
Here are the two chapters in the workshop manual that should help.
Old 02-11-2018, 12:07 AM
Garker
Garker's Avatar
Thank you for the references; however, neither of the links relate to the clutch or slave cylinder?
Lin
Old 02-11-2018, 12:48 AM
TheBruce
TheBruce's Avatar
Ha! Looks like my print to pdf didn't work as planned. Let me try again.
Old 02-11-2018, 01:01 AM
TheBruce
TheBruce's Avatar
Second attempt.
File Type: pdf
Old 02-11-2018, 07:52 AM
Garker
Garker's Avatar
Thank you!
Lin
Old 02-13-2018, 10:24 PM
Garker
Garker's Avatar
Thanks to Bruce and especially to Cole Scrogham who somehow contorted himself enough to do the job. Got the slave cylinder in properly, but that was not an easy job. Note to self - next time install the slave cylinder when the transmission is out. Very difficult to reach these mounting bolts.
Lin
Old 02-14-2018, 12:19 AM
TheBruce
TheBruce's Avatar
Yea we got hung up on it too when replacing the clutch. The workshop manual actually recommends removing the hydraulic line and leaving the slave cylinder in place, but this means you need the bleed the system. My mechanic said it was faster to just remove the slave cylinder, but we still got hung up on it.
Old 02-14-2018, 08:34 AM
Garker
Garker's Avatar
That was our objective - to avoid having to bleed the clutch. In the end we had to remove the hard feed line from the slave, un clip it from its retainer, and bleed the system anyway. Oh well. Live and learn.
Lin
Quick Reply: Replacing 997.1 clutch slave cylinder
