Battery Keeps Getting Drained!
I’ve been in the bad habit of leaving the key in the ignition in all my cars for years when in our garage. This works for older cars like my air cooled but not my 997.1 C2s. If you leave the key in the ignition in the OFF position it will drain the battery over night. Ask me how I know!
I’ve been in the bad habit of leaving the key in the ignition in all my cars for years when in our garage. This works for older cars like my air cooled but not my 997.1 C2s. If you leave the key in the ignition in the OFF position it will drain the battery over night. As me how I know!
That said, I also put a larger agm battery in mine. In order to save weight (and cost, which gets on my **** a little) , Porsche puts in really small and cheap batteries. You can clearly see where the mounts are for a larger form factor battery.
Since I put the "good" battery in mine, I don't even have to use a tender anymore. I can let it sit for well over 2 weeks without any issues.
I left my car unlocked the day it was delivered... the next day the battery, the battery was too low to start the car. I charged the battery and lock the car all the time now. Never had another problem. I do occasionally give the battery a good slow charge if voltage drops to low 12s. Fully charged, this battery is around 14.3 v.
