997.2 C4S : Cold weather, "squeaking" noise from front wheels when turning sharp
Old 01-12-2018, 08:57 AM
Frank996
Frank996's Avatar
Default 997.2 C4S : Cold weather, "squeaking" noise from front wheels when turning sharp
Lately it's been around 0-5C (32-41F) where I have my car parked and I have noticed that when I reverse out of the parking booth and turn to the left (or right for that matter) at very low speeds, the front wheels are making a squeaking noise almost like they are not turning at a different speed than that of the opposite wheel (makes sense?). This is not only when reversing but also when in Drive and again only at very low speeds.
Is this something I need to have checked out (still under warranty but will extend for a year) or is it (as I think I have read elsewhere) a design flaw from Porsche and nothing but an embarrassment... Again, this is only at very slow speeds and sharp turns.
Anyone have something to share on the topic?
It's still a 2009 997.2 PDK C4S...
Old 01-12-2018, 09:02 AM
DC911S
DC911S's Avatar
Most AWD cars do that when they are cold due to the tires crabbing, Audis do it really bad. Car has been sitting and tires are cold, and you make sharp turns in the wheel at parking lot speeds. Don't worry about it.
Old 01-12-2018, 09:10 AM
Frank996
Frank996's Avatar
Thanks for your reply DC911S... I just don't recall having the same sound(s) with my old 996 C4S back then but I believe what you're saying... Again, it's not a "something-is-seriously-going-wrong" sound...
Old 01-12-2018, 12:15 PM
Wayne Smith
Wayne Smith's Avatar
Received 1,152 Likes on 731 Posts
Not only does the inside wheel turn at a different speed than the outside wheel, the insides of the tires turn at a different speed than the outsides (of the same tire). Somethings got to give. When cold, summer performance tires "squeak" when they give. These tires are generally specified for higher ambient temperature. Winter tires tend to eliminate the noise.
The above is a very partial explanation. There is a lot of previous discussion on this topic on this Forum. Try the search key for additional reading.
BTW, this is not limited to only AWD cars.
Old 01-12-2018, 05:22 PM
Speedvagen
Speedvagen's Avatar
I had something similar on my 997.2 C4S but this happened in the summer. So not sure if it is related to your issue. But I ended up needing a new steering rack. Thankfully covered under warranty.
Old 01-13-2018, 08:03 AM
92C2Targa#119
92C2Targa#119's Avatar
It maybe control arm bushings too.
Old 01-13-2018, 09:59 AM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,247 Likes on 783 Posts
My AWD 997 did this too; moreso than my AWD 996. It’s normal.
Old 01-13-2018, 10:20 AM
Petza914
Petza914's Avatar
Received 6,170 Likes on 3,934 Posts
Do a search for Ackerman effect and you'll see it's completely normal and has to do with the design of the front suspension geometry. Usually it's described more as a clunk or pop than a squeak but I'm sure it's the same thing. Backing up with lots of steering angle at low speed when it's cold out. Nothing to worry about.
Old 01-13-2018, 06:35 PM
vern1
vern1's Avatar
Normal
Cold weather 0-5C?? Was -33 here last week.
Wimp
Quick Reply: 997.2 C4S : Cold weather, "squeaking" noise from front wheels when turning sharp
