2008 Porsche 997.1 missing the red jump fuse
My battery is dead so I tried to power the red pull out fuse in the kick panel. That's when I noticed I don't even have one! My 01' Boxster has one but it's missing in the 911. It looks like it was never even in the box. I don't see anything in the spot where it goes showing something was there before.
Anyone else have this ? Or not have it I should say. I wanna open the frunk to jump the car.
I remember reading that the pull out fuse can be pushed back in so far that it may not be easily seen or even pushed into the space behind the plastic fuse panel.
Sorry for my ignorance folks, but what is it for? Why is it important?
TIA!
TIA!
aha! Thanks folks. Will need to check on mine when I get it out of storage. I don't remember this being an option on my Boxster (an early version 986 - 03S; maybe did not have it)
i first thought my car did not have the red jump point as well. It had been pushed back way into the fusebox. I had to stick a flashlight in the hole where it normally is to see it hiding behind. I spent sometime with a needle nose plier to putt it out but just ended up scratching it. So,to get it out you need to remove the 3 philips screws and remove the trim surrounding the fuse box (see attached pic). Then from the right side of the red jump lead you can stick your fingers behind the fuse box and push it out through the hole. SImply diy and should not take more than 5 minutes. Just need a screwdriver thats all.
jaiuttam (01-24-2024)
