Leak on underside...cause?
Just a suggestion. I had a 1999 996 with Tiptronic. I was starting to get a bit of a weep from the trans pan gasket. I went around the pan and snugged up all the bolts (carefully - don’t lean on them). Some of them were loose and took about a quarter turn to tighten. Then I used brake cleaner to clean off all the crap that had collected. I never had another issue after that and I kept the car for about 3 years after that.
I have the same car but mine is an S. There is a seal on I think the torque converter housing that I saw some thread where a guy took it apart to fix. Supposedly it is one of the more common problems. I’ve ask both my dealers and they have never seen the issue to maybe not so common.
Anyway I would clean it real good and check it in a thousand miles. If it has never dropped it can’t be much. At least if you clean good and look later you might be able to nail the source down.
Oh dear, I had the same issue on my 996.2 Tip, C4.
I had the bolts tightened, still leaking, the seal replaced, still leaking, transmission connector replaced, still leaking but on one side only.
Fortunately(?) 996 has less underbody panels allowing quick and easy inspection of the transmission pan for leaks. At the end I had to wipe the leak every month or so otherwise it'd start dripping on to the garage floor.
I posted a couple of times re this in the 996 forum - at the end there was no resolution for me.
I spent a few hours under it yesterday and cleaned everything up the best I could (4 post lifts are a life saver). I will get some new pictures up to see if its still leaking in a few days and see if the drip pans show anything.
Thanks for the help so far!
