997 GTS Journal from Istanbul
#122
Clubber:
"I ordered them in an odd combo. Fronts are 19x8,5 ET53 which is GTS size but I went for 19x12 ET48 (GT2 RS size) on the rear to fill the arches better. GTS rear size was 19x11 ET51 which really hides the wheel on the stock car. It is more flush with 12 rears."
Thanks for the info.
Do you have any rubbing/clearance issues with them?
Did you put 325/30ZR19 rubber on the rears?
My 997 GTS suspension is stock, and I dislike the OEM Spyder wheels silver rim and the non-flush appearance with the wheel well opening. A 325 rear patch increase is also appealing from a performance standpoint.
I found the Ultraleggara 19x12 ET48 are available special order (2-3 months) from the Tire Rack, here in the US. They were reluctant to recommend the 19x12's, since their computer does not guarantee compatibility with the 997 GTS.
Here is my planned conversion:
If you can verify that you have mounted and driven with Ultralegerra 19x8.5 ET53 and 19x12 ET48 with 325/30ZR19 rubber on a 997 GTS with stock suspension, and had no issues, I will go that route.
When/if you lower with Eibachs, might that create a wheel well clearance issue with the Ultra's?
Thanks for any help. Your car is fabulous, as is your photographer.
The Sport Classic mods are all tasteful and aesthetically pleasing to my eye.
You have great taste. My GTS is jealous.
This pic was taken with an iPhone 6S at Jenner by the Sea (Where the Russian River meets the Pacific Ocean) in Sonoma County, California winter of 2016:
#123
Clubber:
My 997 GTS is suspension is stock, and I dislike the OEM Spyder wheels silver rim and the non-flush appearance with the wheel well opening. A 325 rear patch increase is also appealing from a performance standpoint.
Regarding the fitment ; There’s no rubbing or anything BUT I’m using oem 305’s in the rear. There was no stretch on the tires as you can see and I didn’t want to put 325 for potential rubbing in the future with springs. So far, pretty happy with the look and ride.
#125
You are most welcome.
#126
Cool. I will go with this package:
It is nice to know ahead of time that a fitment will work. Glad we have identical OEM supensions and your set up has no issues.
The seller's computer would not accept the rear wheel combination for our 997 GTS.
Thanks again.
Thanks again.
#127
#128
Here's a quick video of the wheel application , hope you all like it.
#129
Wow. Thanks for the video. Nicely done.
Your explanation of the 997GTS front wheel wells being narrower than the 997GT2RS prevented me from buying 19x11 ET47 wheels.
I will stick with the OEM 19x8.5, and as your video pointed out, the OZ's in that size (with ET53 offset) will bring the wheel out flush with the wheel well lip. Two Rennlisters have PM'ed me with verification that the OZ 19x12 with MPSC4 325 fits with stock suspension and no issues. One of them has SPORT PASM (-10mm lower than my base PASM) and reported no issues.
You said your MPSC4 305's fit on the 19x12 with no sidewall stretch, but you avoided the 325 since you may be lowering yours with Eibachs.
I have no plans to mod my suspension, so will go with the 325's, which was the stock 997GT2RS setup. Any advice on that decision?
Thanks again.
I really like the OZ look on a stock 997 GTS, and hope the black color works with my Basalt Black Metallic (BBM) color. If the color looks "off" like your white did, I will have them resprayed in BBM color for an exact match. The OEM CL Spyder look wheels are not an exact color match and look fine. Maybe black is more forgiving of different color shades than white.
This red body sure looks cool with the red calipers and CL hardware trim on the OZ's:
Thanks again.
#130
As for the EIbach springs, they do look better but it's not low enough for my taste especially in the rear. If I were you, I'd go with some Bilstein coil overs right away. I will invariably be doing that in the future as you can keep the PASM functionality even using the button on the dash, that's my understanding at least. Maybe my car doesn't have as much of drop as it's a C4GTS.
#131
Thanks again.
Thanks again.
I love it, car looks amazing. I was seriously considering a duck tail but lost interest. After seeing yours I'll have to revisit it again lol. It'll be awhile as I'm buying an RS4 next week and also getting married this year.
That is the exact reason I went for Eibach's. A modest drop is all I need. They are going on tomorrow, will put before and after shots here in a few days.
#132
Finally dropped on Eibach's. She'll probably drop a little more once they settle but so far I love it. Didn't realize how much it would change the look,
#133
Great build.
For my cab, I'm looking to go from H&R springs to OE SPASM or Eibach and get OZ's for the offset change. Your thread, detail, and pictures are very helpful.
Thanks so much for sharing!! Enjoy your fabulous GTS.
#134
Thank you for the kind words. Glad I could help.
#135
Clubber wrote:
"Glad I could help. One other reason I avoided 325's at the rear is the weight penalty. As we bared saved half a kg with OZ's wider and heavier tires would probably mean losing that little saving only for an almost unnoticeable handling boost. If you want to go with 325's on 12J rears, that is totally understandable. One other ocd of mine from my ///M culture, I don't like having too much width difference between front and rear. 235-325 is almost 10cm tyre print difference."
I am not concerned as much with the weight penalty. Unsprung weight is, of course, to be minimized. But my OZ purchase/mod has more to do with bringing the wheels out flush with the wheel well lips. I do not track my car, but do drive roads that are as demanding vertically as laterally. I am not seeking a super lowered look. Your GTS with Eibachs is beautiful, but I actually prefer the "before" stance, it looks better prepared to deal with real world road conditions vice the laboratory setting of a racetrack.
Here is one of my favorite roads:
Latigo Canyon Malibu, CA
HIGHEST POINT: 2,122 ft
VERTICAL GAIN: 2,016 ft
LENGTH: 9.2 miles
GRADE: 4.2% average, about 12% max
So, what I am most concerned with is not compromising my suspension clearance.
(And the OZs look way cooler then the stock Spyder wheels.)
Not familiar with BMW M3, but a large front/rear wheel width disparity is a non-issue on a 911.
Thanks for sharing your mod's. Between you and nwGTS, this is a personalized tutorial on 997 GTS tuning.
yo
LENGTH: 9.2 miles
yo
