Seat swap: memory comfort to non-memory sports
Been searching for awhile and can’t seem to find a definitive answer on this... I currently have standard comfort seats with heat/lumbar and memory and looking to swap those for a sports seats (not adaptive) with heated, but no memory. Other than losing the memory function will there be any issues? All I need is for the seat tilt and heating functions work.
Under my drivers seat I have the standard connector and an extra memory module and was planning to leave the memory module unplugged.
Many thanks in advance for any insights/experience...
Did a quick test: unplugging the memory module causes the seat to lose all power which is not encouraging but hopefully the circuit that causes in that behavior is on the seat side and not on the car side. Anyway, looking forward to hearing from others.
Thank you..! I looked under mine and saw the red/brown thick wires going into the black memory module. Looks what’s needed is to connect those wires to the new seat along with the other connections like airbag, seatbelt sensor etc and I should _hopefully_ have a fully functional seat.
Newold_M, Just checking to see if you did this on your car. I've got the comfort with memory, heat in my '12 GTS. Wondering if any version of sport seat will plug into my car. How'd yours work out?
Search for my thread on the swap. If I recall correctly, it was a pretty detailed write up.
You have to tap into a 12V line under the seat.
I'll see if I can find it.
It was on P9, read through the thread towards the end. Photobucket screwed up all the photos but it might still help. I think there's a hack to bring up the pics on chrome or something. Not sure why I didn't post this here.
http://www.planet-9.com/987-cayman-and-boxster-modifications/101881-sports-seats-instead-memory-power-seats.html
Thanks for the reminder as I've been meaning to update this thread. Yes, the swap as a success! What I had to do was to take apart both memory and primary seat connectors and move the positive (red) wire from the memory connector to the primary connector. There is already a ground wire (brown) on the main seat harness so no need to move anything else from the memory harness. Before you do any take apart be sure to disconnect the battery otherwise you'll end up making a trip to the parts store to get a new fuse
How to take apart the connectors:
red power line on left that needs to be moved:
and moved... No codes and everything works as expected and passenger side mirrow still dips when put in reverse. Let me know if you have any questions..
