Blown Door Woofer
Dougkeen...glad you are happy with it. Love the fact that the 2007 GT3 is giving life to others. :-)
I still have all of the Bose speakers if someone is interested in doing that complete speaker upgrade to a non-Bose car.
To just upgrade the OEM speakers to the Bose speakers (should have larger magnets, wider acoustic range, better quality components, etc) you can just replace the non-Bose speakers with the Bose versions - they connect like any other speaker with a + and - wiring pair.
unfortunately the bose speakers are no where close to fitting in the OEM non bose speaker housings. I would need to have custom brackets made to fit the speakers in the car.
Any pics of the fitment issue as we might have some ideas. I'd be surprised if the door panels between a Bose car and non Bose car are different and it might just be the mounting ring you need to make them work. When I replaced them with my Focals, I used the original speaker mount but had to clip out the plastic gridding due to the larger magnet and deeper depth of the Focal Speaker, like this:
Original Bose Speaker (internet photo)
Cutting the rear gridwork out of my mount to accommodate the Focal speaker
Speaker mounted with protective BoomMat enclosure
Front view of new speaker in mounting plate
Speaker mounted in door
If the plastic ring looks like what you'll need, here are a couple for sale on eBay and I will split the cost with you (send you $35 via PayPal) so you can buy them to finish the job. They're from the same seller so maybe he'd even give you a deal on both.
https://www.ebay.com/itm/2006-2012-P...ZZe1pW&vxp=mtr
https://www.ebay.com/itm/2007-Porsch...5aOsYA&vxp=mtr
Let me know what you want to do.
Yeah we were thinking about this as well. The issue is that the non bose plastic speaker housing is different than the bose one. It is smaller so the mounting points for the speaker to the plastic speaker housing are different. If I had the bose speaker housing it would be plug and play.
