Bronz's 997.2 C4S
#47
Thanks guys! Pics should be working, might be your firewall or something blocking the pics.
Exhaust install has begun!
#48
Havent noticed it but the pins are made out of super light weight aluminum so i assume its pretty soft and the knurl is not very sharp. Ill look into it tho
#50
Attached are the instructions for adding factory PSE in case anything in there is also helpful. I don't know what the silver tank is though or the black and white dual barbed piece - that looks like a 1-way vacuum check valve and the tank looks like it's for air storage, but I don't know why that would be needed. When I connected my Fabspeed valvetronic mufflers to the PSE system in my car, I just had one hose from the vacuum solenoid in the engine compartment to a T and then a hose from each muffler valve to the T.
I noticed that the instructions above are for the 997.1. Anyone know if the PSE retrofit instructions are the same for the 997.2? I’m assuming it can’t be that different. Thanks for the good info.
#52
#54
#55
Great upgrades. How is the ipe exhaust? Any video/sound clips?
#56
Any updates on the exhaust?
#57
Exhaust is in, but i havent hooked up the vacuum/electric yet. Its snowing out here today and the temperatures are freezing. The good thing is exhaust sounds amazing the way it is now, but im not 100% sure if its in closed or open position right now. My bets are its open as it sounds mean and exactly what i was looking for. As soon as everythings buttoned up, i will definitely make a video and post it on here.
Finally installed the GTS front lip as i was missing one. Wheels are supposed to go on this week as well.
#58
#59
Installed Rial Daytonas yesterday so my friend took some beautiful hi res shots of the car. They look amazing but i feel like the car needs a drop to pull them off properly. Lowering is not on my list so these will be for sale if anyone is interested, let me know!
#60
Hate to be Debbie Downer, but agree on the need to drop. I like the wheels, but gaps are too large for the added flash. And this is why I’m still on stock wheels. Flash wheels need low to pull off the look. Work Meister S1 3P in gold are in my distant future. But only when the Olins Road & Tracks go on.
