Recommendation for aftermarket headunit?
I'm looking to replace the PCM 2.1 Jurassic era headunit in my new-to-me 08 C4 with something more modern that can do bluetooth/usb charging/backup camera at a minimum. What headunits have y'all used and which do you recommend?
I also have an 08 C2S. I went crazy and completely upgraded the audio with a full cockpit sound deadening, new JL Audio amps and Focal speakers. I chose the Pioneer 8201 NEX because it brought the whole package up to 2017 standards. Backup cam, GPS Nav, full DVD video while cruising, BT, CarPlay, HD FM Audio. I can rock out when I want the sounds and volume down to enjoy the engine. Love the Pioneer unit. Worth every penny.
Nice, thanks for the recommendation. I've been looking at Pioneer head units too. What do you think of the AVIC-6200NEX?
To piggy back on this thread:
Anyone kept steering wheel controls? If so, how?
Also what adaptor did you use for the fiber optics?
thanks!
thanks!
Impressive! Who did the install, and are you happy with the quality of the work?
My audio guy is local in the NE Philly suburbs. PM me if you want contact info. I took a chance, as the shop was not impressive, just had great reviews when I was researching. The owner was a great guy who had done a couple of other 911's and so knew the interior and the amp/speaker set up. I was honestly impressed with the thoroughness and detail of the work. They had the entire cockpit stripped out for the full install. The only issue I found after delivery was that the hardwired V1 12 volt power supply wasn't reconnected correctly. He had to removed the headliner and sunroof to lay the sound deadening material, then forgot to reconnect the ground wire. That was fixed in 15 minutes. The sound quality is surprisingly good in my opinion, similar to a Mark Levinson system in a Lexus sedan I owned previously.
Hey Gents.
I know this thread was from almost 1 year ago, however, I recently acquired a '07 Targa 4 with the 8200nex already installed. It's a great aftermarket unit and sounds amazing! My question is whether there's a way of utilizing the OEM cd changer with it? I was working on the switches the other day and noticed that there's some RCA cables capped off which could be from the cd changer, but not sure if or how to connect them. I also noticed that it has the 997 MOST hur unit with a USB cable attached to it, but not connected to anything else. Any ideas what this might be used for?
Cheers and thanks in advance!
