997.2 C2 + Turbo II Wheels + Eibach + 7mm/15mm Spacers + Michelin 235/35 305/30
I think the new PS4Ss have kind of the same "flat/squared" sidewalls that PSSs have. I will try my luck and order the PS4Ss in 305/30.
yup correct. i'd just run the 15mm on the rear, wouldn't worry about the extra mm to match the oem wide body rear wheel specs.
only the genuine turbo cars came with the 8.5 inch fronts as they are made wider and more aggressive to account for the wider front turbo bumper
when are u going to get all this installed? it will look amazing.
You are absolutely right; 997.2 Turbo II WB wheels are 11" wide and not 11,5". But the math is right (I believe) which gives 16mm spacer (67mm - 51mm).
https://www.suncoastparts.com/product/G1997TT2WHL.html
Dimensions (Carrera):
Front - Rims: 8 x 19 57mm - Recommended Tires: 235/35 ZR19
Rear - Rims: 11 x 19 67mm - Recommended Tires: 295/30 ZR19
Dimensions (Carrera 4):
Rear - Rims: 11 x 19 51mm - Recommended Tires: 305/30 ZR19
Dimensions (Turbo):
Front - Rims: 8.5 x 19 56mm - Recommended Tires: 235/35 ZR19
Thanks for the heads up.
Dimensions (Turbo):
you're totally correct; i meant re the turbo II wheels.
the 997.1 carrera sport wheels also came 8.5/11.5 and same with the 997.1 turbo wheels also 8.5/11.5
cant wait to see this beast transformed!
Correct me if I am wrong.
The below GT3 (rennlister Marvin Zoch) has the following front wheels:
Front: 8.5"x19" ET 53
Turbo II NB wheels:
Front: 8"x19" ET57
According to the wheel offset calculator:
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
Outer Position: RETRACT by 10mm
Is this "10mm" the size of the spacer that I have to add to have the same front wheel stance?
Turbo II NB wheels:
Front: 8"x19" ET57
If I am reading your post correctly, you are asking what size spacer for 8 et57 TurboII wheel that will give the same outside spacing
as a 8.5 et 53 wheel.
If so, then you are correct, 10mm spacer.
About spacers, after exchanging some PMs with rennlister WantA997, I decided to go with 10mm front and (per MYW's suggestion), 15mm rear. Now, 10mm spacers are only offered by ECS and Adaptec - both rennlist sponsors
I am trying to decide if I will go with silver or black lug bolts. ECS only have spacers and lug bolts in black. Adaptec only have (besides custom made) spacers and lug bolts in polished aluminum color (silver).
So, these are the options:
1) Adaptec spacers and lug bolts in polished aluminum color.
2) ECS spacers and lug bolts in black color.
3) Adaptec spacers (aluminum color) + ECS (black lug bolts).
What you guys think?
no company out there makes a gunmetal spacer + lugs?
10mm FR like cameron's car is good, just don't do the 7mm. with that said that extra 2mm (12mm FR) will also work without issue
your car will look amazing either way.
