CPO and Spark Plugs
CPO and Spark Plugs
So I bought a CPO'd 2009 C4S Cabriolet last November w/ 22k miles. Yesterday, I took it to same dealer for 30k service, they told me service records indicate that the spark plugs have never been changed and recommendation is that they be changed at 4 years. Given this recommendation, seems to me that the plugs should have been replaced at time of CPO. Opinions?
Very interesting.......and good question about CPO if thats what they are saying.......but really , its a garage queen so why worry! The worry warts will say the plugs may seize with time so you should change them so its your call. If its been stored at a nominal humidity then I doubt that......but due to paranoia may be you should. There is no right or wrong, just opinions on this board.
Personally I would as they are 8 years old, and just because I cold do it myself with little effort on a garage queen. But thats just my opinion of the many you will get. Let the fun begin. Oh wait better yet is... why would you not replace them after 8 years.......because i still have my original plugs in my high performance ski boat that is also a 2009......and I run the **** out of that baby at wot all the time without hesitation and pull the plugs every fall to winterize it. Are you confused yet? i am
Yeah, I read the thread "When do you need to replace spark plugs?", in general, rather than think too much, i tend to follow the manual. However, at this point, i'm more concerned about the principle. Should they have been replaced by the dealer at CPO?
I have an 09 S with 22k miles as well... because I love to work on the car I did change the spark plugs... original ones were fine and car behaves the same on new spark plugs - btw, I used Bosch and cost me like $50... so peace of mind in my case... all of this to say, you should be fine as you are
having said that, I did find 2 coils with hairline cracks... I replaced alll 6 with Beru ones - cheaper than Porsche and guess what, same as Porsche uses... they were not affecting normal operation of the car, but they could have in time... so I did
cheers
cheers
I experienced the same with my CPO 2011 C4S last August. The selling dealer did not change the plugs when I bought the car with 12,000 miles.
Since Porsche recommends to change them based on mileage or at 4 years, I reached out to the dealer and they paid for the spark plug change at my local dealer.
Excellent service from both.
Indeed, if the maintenance schedule call for the plugs to be replaced before the car was sold to you, the dealer should have replaced them. Having said that, I just recently replace the plugs on my 2008 C2S at about 27k miles ( nearly 9 yrs old). The car ran well before and runs well after the plugs were replaced. The tech said the plugs looked good. I do replace the oil and filter every year (~3k miles) and the brake fluid every two years but with plugs, I would focus more on the mileage. If I drove my car in rain and snow, I am sure I would have needed to replace the ignition coils sooner as they are made from glass filled polyester and that material hydrolyses ( mine are always dry).
I don't think plugs would have been covered under the original factory warranty. Also, my CPO warranty info specifically excludes plugs. So I'm not sure there's a definitive "yes or no" answer - you're right in that this will be a good test of the dealership. Good luck.
Bravo ! Especially since Porsche CPO "does not cover... the replacement of expendable maintenance items (such as... spark plugs)" unless there is a defect in material or workmanship.
https://www.porsche.com/usa/approved...ures/warranty/
Perhaps they were changed, but whoever is trying to charge you for the service again is not seeing this in your records. They might have to call the dealer performing the major service to obtain those records. If not performed, ask the CPO dealer to pay for or contact Porsche NA.
The dealer that did the CPO and the dealer doing the service are one in the same
My major was performed at a Porsche dealership in a different city, but my local dealer had to call them to confirm that because it does not show up on their screen.
I dunno, just trying to figure that one out. They should pay for this service or I would get Porsche NA involved if that service was due time wise when the car was certified.
