Water Pump DIY Fail - HELP
Pete, great advice on the taped extensions. New pump in. New plugs and coils. Fired it up without mufflers and cats to check for leaks and misfires before full reassembly. Sounded like a biker rally. Neighbors came out of their homes to check out the window shaking ruckus. All good to go. Pipes go back on tonight.
There are no shortcuts. You must remove the entire exhaust system to get to the bracket, then remove that in order to access the water pump and attendant idlers, belt, etc. If you try to take shortcuts you will be rewarded with much pain. End of story. Don’t ask how I know.
