Bose Head Unit Replacement in a 997S for under $150 and in 30 minutes or less....
UPDATE:
Everything continues to work well. I checked and the balance control from L to R works fine with the MOST HUR unit but just like all of the units, the fader control does not work. If you fade to F the volume goes down completely and fade to R gives you full speaker volume. Keep it zeroed out and make sure your factory unit is zeroed out when you disconnect.
Also I get a slight pop from the speakers when I turn off the ignition. This appears to be because the aftermarket stereo is turning off before the Bose amp has had time to power down. It would probably be an issue with any MOST HUR unit and many other traditional aftermarket installs that work with separate amps. The solution is to have the amp (MOST HUR box) direct wired to the ACC to shut off immediately and then run the head units ACC line on a delay diode/circuit so it delays ever so slightly shutting down AFTER the amp does.
Its not a huge deal but if you want it perfect, that may be something you want to do.
Mike
Mike
I also bought this MOST from same seller and had an installer do it for me. I hear background noise (or radio) when my 4200nex is ON but NOT playing anything. Have you noticed similar thing?
I have asked seller about this and he said he will send me in/out filter to get rid of this but I honestly don't think thats the issue.
Hi Mike,
Mike
I don't think it is head unit but MOST device. I heard same issue on the other forum as well. There is no background noise at all in your set up?
None at all for me. So it's possible there are either differences in quality control or differences in our installation or differences in our components but I don't know which one it is.
The following 2 users liked this post by devioustrap:
Jberkley17 (05-03-2020),
Kbasa (12-24-2022)
The Blau San Jose is not a nav receiver. You can buy any head unit you want though if you want one with Nav. There is a $400 Sony media receiver that does Car Play and Android Auto so you can use your phone's nav and other functions on screen.
https://www.crutchfield.com/p_158XAV....html?tp=72381
Plenty of options out there. Just depends on what you want in features.
Mike
Mike
Hi Mike,
if it's just alternator whine, then a ground loop isolator would fix that. if it's just noisy, it might be because of quality connectors on the HUR box and not much to do about that.
Is it alternator whine? I noticed that the HUR box thing doesn't exactly have the best quality RCA connectors...
Anyone know how to fix it?
Mike
Thanks for posting your ebay MOST HUR find and review. I ordered the same adapter and will be replacing my head unit this weekend.
The screen on my stock unit died over a year ago. Everything else still works, I just have to navigate settings by memory. I procrastinated replacing it, bc I thought my only option would be $1000+.
I am not sure if I am the only one having this bad noise or others having it as well. Long story short, I replaced it with NAV-TV and I did not have this problem at all.
My 2 cents
