Annoying rubbing noise pass door 997.2s cab
hi All... I know this is a difficult issue to describe and debug... but thought I would throw it into the forum see if someone has any suggestions... has anyone had a rubbing/rubber noise on the door? u can hear the squeaking on irregular pavement... I have rubbed Gummi Pflege all over rubber and even body and cannot eliminate this gremlin... car is always garaged, 2009 with only 20k miles... thanks in advance
Gummi pflege you have to apply then rub off or it squeaks.
