Question regarding Function First transmission mount insert install
Hi,
I am planning to install the Function First transmission mount insert. I did my research regarding the torque specs. One spec that I want to confirm is for the nut/bolt that passes through the transmission mount bushing. From my research, this is 48 lb-ft. Is this correct? Just want to double check as this seems a bit low.
Thanks,
Brian
Thanks,
Brian
