Best practices bodyseal rubber care?
Old 09-18-2017, 03:38 PM
Iceter
Iceter's Avatar
Originally Posted by Edgy01
A very good solution for rubber is talcom powder. It's handy to do prior to winter, when residual water can make cracking a door open in sub freezing weather somewhat difficult. Sprinkle it on, and rub it in. (Do not use vaginally).
Dammit Edgy, I was all fired up to make a joke about your talcum powder suggestion and then you had to make that disclaimer at the end of your post to lock me out.
Old 10-06-2019, 01:58 AM
Paolo1
Paolo1's Avatar
Does the Shin Etsu Grease attract dust? I believe I read that the nextzett 'Gummi Pflege Stift' Rubber Care Stick will not attract dust.
Old 10-06-2019, 11:26 AM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,654 Likes on 987 Posts
No. Good stuff... rub it in. I've had it now for a while and like it. However, I found the Zaino Tire Gloss rubber stuff is great for plastic and all rubber bits and is easier to use. I contacted Zaino and they said it is great for interior plastic. It is not a shiny as it implys... just perfect for me so I use it more than the Shin Etsu Grease.
Peace
Bruce in Philly
Old 10-06-2019, 12:29 PM
TheBruce
TheBruce's Avatar
When I bought mine the rear and passenger window trim was all oxidized and spotted. Likely from the prior owner taking it through a car wash. I actually found just a damp rag with some heavy pressure removed the top layer of black gunk and made them look new again. I then used that gummy phlegm everyone talks about :-)
Old 10-06-2019, 05:11 PM
Steph1
Steph1's Avatar
I second the shinetsu grease that is available at your local Honda dealer. I've been using it for over 5 years on all my vehicles.
It was recommended to me while I was looking for a solution to take care of my front roof panel leak on my Jeep wrangler. It worked immediately and I was sold. Best part is that it does the job real well and is absolutely not greasy.... I used it on all my seals at my yearly oil change/ maintenance and it never leaked again
Old 10-06-2019, 06:17 PM
platinum997
platinum997's Avatar
I just did this today and looks and feels so much better.
How often are you applying? I was thinking after every detail so maybe once or twice a year?
Also, can you get this on the paint without issue. I was fairly sloppy with the application and then just rubbed it off with a cloth.
Old 10-06-2019, 07:20 PM
Steph1
Steph1's Avatar
I'm quite certain it doesn't affect the paint. You could maybe do it in the spring and fall, but I always did mine once a year with the oil change.
Old 10-06-2019, 10:39 PM
EMC2
EMC2's Avatar
Originally Posted by Iceter
I second this. Shin-Etsu is just the Japanese version of Gummi Pflege, and is usually cheaper. The only problem I have found with Shin-Etsu is that one tube will last you several lifetimes.
I'll add one more for Shin-Etsu. Excellent for the seals and also the windscreen cowl panel.
Old 10-06-2019, 10:42 PM
BLU997
BLU997's Avatar
I was warned about putting any silicone lube near cars, even overspray floating in the air can settle on your car. The trouble comes when attempting to repaint any part of the car, for whatever reason.
Look up "Fish Eyes" as paint defect....
Quick Reply: Best practices bodyseal rubber care?
