997.2 Cab - Escort Passport Max Mirror Hardwire Install (Blendmount + Mirror Tap)
Yet another post to hardwire a radar detector. I didn't see one with my exact specs, so hopefully this helps someone as much as the other posts helped me.
Car: 2009 997.2 Carrera S Cabriolet Detector: Escort Passport Max Mont: BlendMount BMX-2123 Wiring: MirrorTap MTX-1015 (15" - just reaches. can't go any shorter) 1. Remove the dome light. I used a . https://cimg6.ibsrv.net/gimg/rennlis...66a8c1c5f6.jpg https://cimg4.ibsrv.net/gimg/rennlis...59ead19e57.jpg 2. Remove the homelink buttons. There's a small notch - pop them out with a small flathead screwdriver. https://cimg6.ibsrv.net/gimg/rennlis...165bf0e492.jpg https://cimg8.ibsrv.net/gimg/rennlis...a60d494894.jpg 3. Remove the black metal bracket. There's two T30 torx screws in the hole where the homelink switches were. https://cimg2.ibsrv.net/gimg/rennlis...07cf815bbc.jpg 4. Pop out the white wiring harness from behind the black plastic bracket. Remove the white sheath over the harness that goes TO the mirror. In the pic, I unclipped the harness from the other other white harness, but you shouldn't do that... https://cimg9.ibsrv.net/gimg/rennlis...a751e64626.jpg 5. Find the ground (brown) and +12v switched (orange & black) wires. Insert your mirror tap leads (I used one of the smallest sets) - black into brown and red into orange/black - into the wiring harness for those colors. A huge thanks to 1080iaddict and his post from 2005(!) for this great pic below. You may want to follow the steps w/ the mirror tap to use a voltmeter to check these wires - I did. https://cimg0.ibsrv.net/gimg/rennlis...c1f8b84edc.jpg 6. Once the leads are in, attach the mirrortap cable into the leads and the detector. Turn on the accessories with the key and try it out! https://cimg0.ibsrv.net/gimg/rennlis...9e7bc8d688.jpg 7. Put the white sheath back on the wiring harness. It wouldn't fit for me due to the increased thickness of the taps, so I cut the opening with a pair of snips and then taped it in place (red electrical tape). https://cimg8.ibsrv.net/gimg/rennlis...da92d075d2.jpg 8. Tape the mirrortap leads to the mirrortap cable (they give you a small piece of electrical tape) and use the zip-tie to attach the mirrortap cable to the mirror wire bundle. 9. Run the mirrortap cable through the headliner. https://cimg0.ibsrv.net/gimg/rennlis...49eed5bae2.jpg https://cimg7.ibsrv.net/gimg/rennlis...c62cad0053.jpg 10. Put it all back together. - Tuck the white wiring harnesses back behind the black clip - Attach the metal bracket with the two T30 torx screws - Plug-in & re-attach the dome light - Plug-in & re-attach the homelink switches 11. Attach the mount as per the instructions. https://cimg8.ibsrv.net/gimg/rennlis...0e8fe071b8.jpg 12. Power on, drive safe, and enjoy! https://cimg5.ibsrv.net/gimg/rennlis...56244d9410.jpg Questions welcomed :) |
I just got around to doing this. This guide was definitely helpful. I simplified your process a little bit, and there's also a cheaper source for the cable. I ordered one of these guys for $10:
http://www.safe-n-sound1.com/Escort%...%20Mirror.html I also bought their T-taps from here (2x $1): http://www.safe-n-sound1.com/Accessory%20Items.html. You can probably get these cheaper at an electronics store, but it's $2, and they save you the effort of crimping them onto the cord. IMO these are easier to install and to later reverse than inserting pins into the connector. Once you order, send them an email referencing the order and ask them to make the cable ~16" instead of their standard 12. That was about 3 more than I absolutely needed, but there's plenty of room to tuck away the extra; better too long than too short. To install, the steps I took were:
Can this project be done on a 2010 987.2 with auto-dimming mirror? If yes, does anyone have photos of the installation to share?
Are you using a singular radar detector? I hear laser is becoming all the rage for cops now. I have an Escort, but am worried about speeding as I don't want to get caught doing 110 due to a false sense of security.
Originally Posted by raidersfan
(Post 15103540)
An illegal (in many places) laser jammer - https://www.vortexradar.com/2017/10/...ammer-reviews/ A scanner with all of the local frequencies, and a cb radio, and a good radar detector properly configured. It also helps not be driving a Porsche or a red Porsche or a yellow Ferrari etc. I'm convinced that I can go faster more often in more places in a Prius than I can in my Porsche. I also think it doesn't make sense to speed when the payoff is so little. I can speed all the way downtown and maybe save 3-5 minutes in total but if I speed on a 400 mile road trip, I can cut hours from the trip. In Texas most folks go 80-85 on the major interstates. I try to stay just under 100 but go with the flow within 15 miles of any state line or hiway patrol office. I also avoid speeding in city limits even when on an interstate. In Denton TX (north of Dallas) there is ALWAYS local police shooting the interstate. I recently trashed my Valentine V1 and got a Uniden and love it. It's too good and often warns way too early but better early than late. Most of the fun I have in the Porsche is from rolling starts to 60mph. I don't know if cops even care about 'exhibition of acceleration' like they used to. |
Originally Posted by Meursault88
(Post 15103791)
You really have to count on laser overspray from cars ahead of you. An empty road is the worst. The other problem is the hiway overpass on ramp - they often hang out there and shoot laser from behind. If you're really into speeding, a few items are needed,
Sort of resurrecting this, but is this the same process for the hard top? Not sure if there is a difference between the cab and coupe’s Homelink/dome light setup. |
hardtop is the same, i followed these directions and it was a breeze,
Originally Posted by ScootsS
(Post 14455630)
Car: 2009 997.2 Carrera S Cabriolet Detector: Escort Passport Max Mont: BlendMount BMX-2123 Wiring: MirrorTap MTX-1015 (15" - just reaches. can't go any shorter) 1. Remove the dome light. I used a $5 trim pry tool from amazon. https://cimg6.ibsrv.net/gimg/rennlis...66a8c1c5f6.jpg https://cimg4.ibsrv.net/gimg/rennlis...59ead19e57.jpg 2. Remove the homelink buttons. There's a small notch - pop them out with a small flathead screwdriver. https://cimg6.ibsrv.net/gimg/rennlis...165bf0e492.jpg https://cimg8.ibsrv.net/gimg/rennlis...a60d494894.jpg 3. Remove the black metal bracket. There's two T30 torx screws in the hole where the homelink switches were. https://cimg2.ibsrv.net/gimg/rennlis...07cf815bbc.jpg 4. Pop out the white wiring harness from behind the black plastic bracket. Remove the white sheath over the harness that goes TO the mirror. In the pic, I unclipped the harness from the other other white harness, but you shouldn't do that... https://cimg9.ibsrv.net/gimg/rennlis...a751e64626.jpg 5. Find the ground (brown) and +12v switched (orange & black) wires. Insert your mirror tap leads (I used one of the smallest sets) - black into brown and red into orange/black - into the wiring harness for those colors. A huge thanks to 1080iaddict and his post from 2005(!) for this great pic below. You may want to follow the steps w/ the mirror tap to use a voltmeter to check these wires - I did. https://cimg0.ibsrv.net/gimg/rennlis...c1f8b84edc.jpg 6. Once the leads are in, attach the mirrortap cable into the leads and the detector. Turn on the accessories with the key and try it out! https://cimg0.ibsrv.net/gimg/rennlis...9e7bc8d688.jpg 7. Put the white sheath back on the wiring harness. It wouldn't fit for me due to the increased thickness of the taps, so I cut the opening with a pair of snips and then taped it in place (red electrical tape). https://cimg8.ibsrv.net/gimg/rennlis...da92d075d2.jpg 8. Tape the mirrortap leads to the mirrortap cable (they give you a small piece of electrical tape) and use the zip-tie to attach the mirrortap cable to the mirror wire bundle. 9. Run the mirrortap cable through the headliner. https://cimg0.ibsrv.net/gimg/rennlis...49eed5bae2.jpg https://cimg7.ibsrv.net/gimg/rennlis...c62cad0053.jpg 10. Put it all back together. - Tuck the white wiring harnesses back behind the black clip - Attach the metal bracket with the two T30 torx screws - Plug-in & re-attach the dome light - Plug-in & re-attach the homelink switches 11. Attach the mount as per the instructions. https://cimg8.ibsrv.net/gimg/rennlis...0e8fe071b8.jpg 12. Power on, drive safe, and enjoy! https://cimg5.ibsrv.net/gimg/rennlis...56244d9410.jpg Questions welcomed :) |
