996 Turbo Forum 1999-2005
Why is this here?
Old 07-13-2017, 10:11 PM
Fracture
Fracture's Avatar
the rears are P/N 996 361 617 00
Probably safer than 62+mm lug bolts, look at the hub of your Sport Techno's
there a spot where the OEM bolt heads hide in the hub of the wheel
http://www.sonnenporscheoemparts.com...ame=hub-spacer
prices vary, I've seen them as low as $88
Porsche does not make a 7mm spacer, only a 5mm for the front
Old 07-13-2017, 10:38 PM
geetee
geetee's Avatar
Originally Posted by mffarrell
Do you think that the black lug nuts are safe to use? This is all new to me. The car is completely stock, so I am not sure why the black lug bolts were used. Does the silver lug bolts look like the black ones that I have?
The black lug nuts look just like the silver ones that came stock. I see no reason why wouldn't be safe.
Old 07-13-2017, 10:40 PM
geetee
geetee's Avatar
Previous owner had black wheels? Used black lug nuts?
Old 07-13-2017, 10:44 PM
mffarrell
mffarrell's Avatar
No black wheels, but the car is black. Maybe the factory ran out of the silver ones when the car was built?
I still think this is a strange solution.
Old 07-14-2017, 06:25 PM
KC-CarGuy
KC-CarGuy's Avatar
Having run with and with out spacers: 1) IMO the handling around corners is better with spacers. Just feels more planted. Probably the slightly wider stance? Around town you would not feel a difference. On a track yes. 2) The wider stance does give a good look when filling out the wheel well, also IMHO.
Old 07-17-2017, 09:43 AM
ANJ-911
ANJ-911's Avatar
So, does your spacer use the same kind of lug bolts like the front wheels and security bolt to attach to the hub?
Do your rear wheel silver lug nuts have a security nut?
Just seems like kludge job.
Well it turns out that I have the exact same spacer setup as you do:
The setup has been working fine for me, don't think there's any reason to question it or be worried about it. I think it's the factory spacer setup.
Old 07-17-2017, 10:24 AM
mffarrell
mffarrell's Avatar
Thanks! It seems like a crazy setup with the security bolt and all.
Old 07-17-2017, 10:42 AM
ANJ-911
ANJ-911's Avatar
No problem! Yea I think they just used the standard bolt setup each wheel came with for the car, 4 standard lug bolts and one security bolt, to hold the spacer in place. My front wheels each have a security bolt as well.
Old 07-17-2017, 11:42 AM
FRUNKenstein
FRUNKenstein's Avatar
I guess the security bolt is there in case you get a really **** wheel thief: "Oh, these are nice wheels, but they're no good to me because I can't get the spacers!"
Old 07-17-2017, 12:00 PM
mffarrell
mffarrell's Avatar
+1
lol
Old 11-27-2017, 03:39 PM
T Kono
T Kono's Avatar
I have been researching this for a while because I am returning my car to its original state, which includes Technos. I have seen many shots of cars with factory installed Technos and almost all had the black lugs (2004 / 2005), that is what I will use also. (rears only)
Old 11-29-2017, 03:18 AM
SteveMFr
SteveMFr's Avatar
ROFL
D'you happen to be a dad too? My daughters beat me about the head continually for humor like this... LOL
Quick Reply: Why is this here?
