Convertible top problem
Hi all. My 996tt convertible top frame has a bolt or something that has evaporated into thin air. The hinge in question is the large hinge that is the main pivot at the forward lower edge of the frame at top rear of the the door. My copy of the service manual covers the top but not the frame. Anyone? Thx
Thanks for the PDF, I didn't have that one.
After some more examination the hinge is supposed to have a small screw and a flat threaded disk holding it together. Going to have to pull the rear panel and see if they fell down in the body.
996 convertible top problem, anybody can help?
Hi everybody.
I need help with my convertible top, Porsche 1999 996. I can open and close the top with my key from the door on the outside, but when I use the button it won’t work.
any help would be great!
Thank you very much
Nir
Thank you very much
Nir
BTW, you do realize you are on the 996 Turbo Forum and not the 996 NA forum. If you do not get response from the folks here, you may want to post there since there will be many more Cab owners,. The Turbo only made cabs for 2 years, 2004 and 2005.
Also, I do not have an answer for you regarding your problem.
John
John
Check the e-brake switch. I think if it is not making contact the dash switch won't work but the key in the door lock will. Assuming you know to always have the e-brake on to open top.
You don’t need to have the e-brake on to open the top. In fact you can open it while driving up to 31 mph. This is not the problem.
