MAF connector question
I removed my air cleaner assy for the first time. I notice that my MAF connector just pulls straight off, no locking tab like my other 996 NA.
Is this normal? Maybe the locking tab broke?
Thanks!
Thanks!
My other 996 NA has a locking tab that you squeeze to release the connector. The TT connector just pulls straight off. Is this normal?
I don't think this helps (there's no P/N, sorry), but in case it does somehow, here is a pic I have from when I last messed with mine:
Think the only thing you can do,is go to the Pors he recylers and see if they will give you the harness.
There are few if you google.
http://www.southfloridadismantler.com
http://dcauto.com
http://www.partsheaven.com/Default.asp
http://dcauto.com
If anyone is interested I found a source for the Bosch MAF sensor female connector. They cost like $13.50 plus $3.00 for shipping.
I purchased two, and they are a perfect fit, and have the same pn# as original. You will also have to purchase a Bosch pin extractor to remove the connector pins to install in the new connector.
Nice!
