If the ECU is flashed, does it erase the Rev counter
Im looking at an 02 with 70K+ miles and the rev report is amazingly low. Like 1 second of >2 and less that i min >1. It is a 6 speed. TIA, Bill
No it does not erase it. In seconds it does not sound like a lot, the actual numbers sound way more scary. The important thing is how long ago it was. If it was .5 Hrs. ago i would be concerned, 20 Hrs. not so much.
Also, there has been a lot of debate about whether it's possible to collect Range 2's without misshifting, but I can personally confirm that it is definitely possible if you have a tune (even if the rev limit isn't raised, you can hit it hard enough to see a few Range 2 ignitions). You wouldn't expect to see much time there, though, from simply bouncing off the limiter, so ~1s or less is certainly plausible, even if the car has been driven reasonably hard.
Think bouncing off the rev limiter are type 1s.
986 and 996 models have 2 Rev Ranges. Rev Range 1 records ignitions at the rev limiter whilst Rev Range 2 records ignitions beyond the limiter
http://www.911virgin.com/porsche/rev-range-information/
You can easily record type 2s by up-shifting at or near the limiter as your rpms may spike imperceptibly as you press in the clutch and release the throttle during the upshift shift. It happens so fast you don't even see it with the naked eye especially with a lwfw as the inertia of the engine carries it through the revs limiter. You won't feel it as you are off the throttle at that point.
Think its more down shifting to soon bringing it above the rev limiter.
I've read a few other accounts of folks who report similar observations. I think cars with increased boost over stock can hit the stock limiter hard enough to still record some Range 2's.
Well according to the link in my post rev 2s dont happen until 7250, hard to believe you would not see 500 increase in revs! Maybe the info in the link is wrong.
That's true, and part of why I feel obligated to share my experience. Something can't be right.
