Porsche 996 Turbo 60,000 Mile Service & BMC Filter Upgrade at BBi Autosport
Basic Sponsor
Attachment 1344394
We just wanted to take a quick moment to share this Porsche 996 Turbo that recently stopped by for its 60,000 mile maintenance. To improve performance and protection, we used Motul engine oil, Brembo brake fluid, and a BMC air filter. Here are some detailed pictures of the upgrades and services performed.
Upgrades & Services Performed:
Porsche 996 Turbo 60k Service & Multi Point Inspection
60,000 Mile Service Kit
Factory Porsche Maintenance Checklist
We used the Motul fully synthetic engine oil instead for the best performance and protection. Other grades of Motul are also available
High Performance BMC F1 Replacement Air Filter
To help the engine breathe a little easier, BMC F1 Replacement Air Filters is made of a washable cotton material that provides nearly 40% greater airflow than paper, enclosed in an alloy mesh screen which helps the filter keep its shape and protects against larger debris and dirt. The increased flow of air through the filter provides a steady stream of clean air to the engine, resulting in much more consistent and efficient power.
Spark Plugs.
Porsche recommends that they be replaced every 30,000 miles.
Brembo HTC Brake Fluid
To ensure optimum stopping performance, brake fluid should be replaced every two years because it can absorb moisture over time and also lowers the boiling temperature, reduce braking effectiveness.
BENEFITS:
As a dealership alternative, BBi performs all minor and major factory scheduled maintenance services for all Porsche models, conveniently serving Orange, Los Angeles, and Riverside Counties. All maintenance services are performed in accordance to factory guidelines as we work very closely with Pacific Porsche, Porsche Downtown Los Angeles, and Circle Porsche dealerships for up-to-date factory technical support and genuine parts.
To get a quote or schedule an appointment, please email us at Sales@BBiAutosport.com or Jerry@BBiAutosport.com.
- Jerry@BBiAutosport.com
- Motul Synthetic Engine Oil
- Oil Filter
- Cabin Air Filter
- High Performance BMC F1 Replacement Air Filters
- Brembo HTC Brake Fluid
- Fuel Filter
- Spark Plugs
Spark Plugs.
BENEFITS:
- Brembo HTC 64T can handle high temperatures without loss of pedal feel (independently proven low compressibility).
- Has been specifically formulated to provide the highest performance and consistency under all racing conditions.
- Has an extremely high dry boiling point
- The higher viscosity of this fluid delivers a “stiffer” pedal and provides stable performance under extreme temperatures (critical in professional motorsports)
- Boiling Point Dry: 335 C / 635 F
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
How often should that be done? I did mine with the spark plugs when I purchased the car but am curious if people continually change them or only if they have problems (once they have the newer spec).
It doesn't make a whole lot of sense to leave original coils in a 12-15 year old car...
Not sure if I'll replace the coils when I do the next spark plug change since the coils are fresh, but I still may swap them out while we're in there...
you have a tuned 996 turbo and you don't also swap coils ( at least ) every other plug change? you're daft and/or cheap. its an add'l 200 bucks on parts on your annual ( semi annual? ) tune up of a nearly 600 hp car. lol.
( add: not you, road king ) ..sorry, just a general observation/comment ).
is your car seal gray btw? if so? we may have met. either way, swap coils 'n plugs same time, next time!
im going to need some kind of empirical evidence of needing to change the coils every 15 or 30 thousand miles. Plugs make sense sure, but coils though should not wear out that quickly I would think.
Not an oiled air filter fan! If over oiled the MAF goes south!
If you havent changed coils and are the originals it's a good idea, since the newer ones are manufactured with a different composite material to ward off cracking.
Our coils are notorious for micro-cracking + coils are a lot of work to get to in our cars + car runs intermittently like crap with cracked coils = change the coils when you are changing plugs to save yourself the headache.
If you don't mind debugging misfires and pulling the wheels, fender liner, tail lights, bumper, intercooler, and heat shields to re-check the coils in between plug changes, and you don't want to waste $200 on something that has not failed yet, inspect them and leave them be if they look ok.
Your basically betting on the odds that the coils will last another 15K miles and potentially saving $200 vs. the above extra work if they do fail before the next plug change... Significantly worse odds if you plan on replacing plugs every 30K as recommended by Porsche instead of 10-15K as recommended by tuners and others.
I am with you. There is no need to do coils with every plug change. If it isn't broken, do not fix/replace it. Cracks can be easily spotted. No cracks, no replace.
