Electrical Issue- Fussy Starting Dash Resetting
An update...
I got both the Audi and Napa part. The $10 one was in stock locally and I thought it could be a backup when and if it happens again.
First, it's a pain lying in the footwell headfirst. Headlight is a must. And T-Rex arms would help greatly. But pretty easy other wise and it cured my stuck key.
Thought I would share the difference in the 2 parts.
The left is the Audi part. The white plastic tumbler is much larger and the plastic is harder. The detents also feel more crisp when you turn the switch. The plastic is also more expertly molded with less injection molding marks.
Thought y'all would find it interesting. But, looks like you do get what you pay for.
Gremlins are back- dash reset this morning after a labored start. I wonder if it's possible I didn't screw the new switch in properly and vibration over the past week of driving caused it to shake loose? I'll slide under the dash and recheck it in the meantime and check the electrical ground strap next.
