dampness around transmission drain plug
Note: The first accumulator I had replaced was 22mm in size but all the ones I installed after were 27mm. I remember trying a crowfoot but I was not able to get it to sit properly on the accumulator because the head of the ratchet or the pry bar were too big.....
If you are a contributor on Renntech, I did a small diy for the slave replacement: https://www.renntech.org/forums/tuto...r-replacement/
thanks jpflip. I am on Renntech and have read your write up a few times. Thank you for that too!
once I get under I'll see if a basin wrench will work too as it has a flexible head and variable bite. I'll report back and maybe save the hassle of buying g and immediately wrecking a tool.
