996tt 1st week of ownership
From what I understood from the previous owner the car still has stock turbos, what's the easiest way to tell? Are they labeled? If I really get on it in 3rd or 4th gear I can get the boost to peak at 1.1bar. The engine will spool up so incredibly fast I find myself watching the tach more than the speedo. Thank goodness for rev limiters 😎
Welcome to the unofficial Seattle 996tt owners club! We should all meet up as a group sometime if the sun ever returns to Seattle.
Until then, you might have Colin & crew take a look at your transmission mounts. I've been running Kevin's LWFW kit for years. The chatter was noticeable but not bad initially (when the car had around 65K miles) then I had Colin install his green tranny mounts which, while cool, amplified the chatter to a point where I no longer enjoyed driving the car. Based on Kevin's (UMW) suggestion, I swapped those out for 997tt mounts and it made a huge difference in the LWFW noise. Almost non-existent now.
It amazes me how much the tranny mounts can effect the LWFW (and engine) noise that gets transmitted into the cabin.
Would be glad to let you hear my car sometime if you're in the Mill Creek area.
I've been reading that it is beneficial to run these cars on the hard side and shift on the higher rpm range. I find that it really comes alive in the higher range and have done some hard pulls and let it run out many times to 6k+ rpms before shifting. How do you guys drive your tts?
You must use the express lanes at night
https://www.speedinginseattle.com/
Or, take in a session here
http://proformanceracingschool.com/v...ic-raceways-7/
They're actually pretty similar in cost, hard to determine w/o a HR monitor which is more exhilarating.
the lwfw rattle is just that there is less material/mass ( hence faster revving etc..) to absorb vibration as compared to the oem dmfw.
There is one particular guy who regularly uses his rev limiter to manage rpm and his friend with a similar style scattered his engine last year. Not sure that contributed but it couldn't have helped. He didn't seem to grasp the concept of a mechanical over-rev when I overheard him discussing the incident.
In an article I read about valvesprings in race engine technology a race team reported valve springs in race engines that were not overreved lasted 10 times as long as those occasionally overreved. One driver went through valve springs regularly, one did not. The other problem is piston g loads that increase exponentially with rpm. One excursion to 8k may not kill it but several might.
He did say shift at higher rpm's, not shift at redline. Higher rpm's can be 3.5-5k rpm.
Better yet, just drive the car EXACTLY how YOU want and don't listen to people left and right because opinions are like butts...you have two sides of it.
I'll go there, since I short shift at the track for one particular corner to avoid a gear change mid corner or having to hold high rpm. I figure the engine will last with fewer extended runs near redline and I have plenty of bottom end with Kevins ZC turbos. Once in a while I'll run most the local track in 4/5 just to concentrate more on line or for a cool down lap, car is still lenty fast. Additionally, the prize money for my events is terrible.
Dan
I shift at high RPM a decent amount of the time but definitely try to avoid hitting the limiter, as it's kinda violent (especially with a tune) and adds overrevs. Even with a tune with stock redline, I see a few Stage 2 ignitions added to the Durametric readout when I bounce off the limiter hard (which is fairly easy to do in second gear -- it runs out quick!).
One of the times I accidentally bounced off the limiter in second, I popped off an intercooler hose and fried the MAF. It didn't turn out to be a big deal, but suffice it to say, on my car, I try to avoid hitting the limiter.
