Oil return pipes from turbo's stuck
I broke (offcourse) the pipes when disconnecting them from the turbo`s..
But they seems real stuck at the other end (the small pump in the waterpump housing)
Any advice getting these off? Heating etc..
I guess I'm not the first one..
Taking them of to get the pipe fittings welded..
I cut it right where they comes into the reservior on the turbo.. Got the rest out of the reservior after cutting..
Maybe a fitting can be used here? M14 male connector to 10mm tube.. Anyone tried this?
Sounds like a corrosion issue, hit with some heat and penetration fluid a couple times and slowly work it.
