New owner..need to replace suspension
#31
pwdrhound - that part number looks like it's for a 997? Will it fit a 996?
I ended up ordering the B8 shocks/struts to compliment the M030 Row Springs. I'm getting advice from most shops as the top mounts don't need to be replaced. Is this just preventative in nature, or are we missing something?
I suppose if I were to replace the top mounts I may go with something a bit more aggressive from tarret or elephant...
For your use I would install new OEM upper mounts and call it a day. Skip the aftermarket mounts...
#32
agree on the mounts. you're going for an approximated oem handling/feel vis a vis nvh, so anything other than the oems will add harshness to your daily ride. replace the top mounts ( you must do ) and the "bearing backing" plates, which are the connected bits. they're on the same linked pelican page as the struts etc.
btw. the top mounts are rubberized "wear items". why you're getting advice NOT to swap them out when replacing most of your movable suspension bits is beyond me. i think that is lousy advice. you'll end up needing to replace the top mounts, sooner or later. why not now! or just wait for the telltale "crunch and creak" show.
but it'll be a totally transformed new "ride". x'lnt choice(s).
