Which brake rotors to install?
#32
Porsche doesn't make brake pads. What you are buying are Textar or Pagid made pads in a box that says Porsche on it with Porsche tax added on. Save yourself some money and buy OEM spec pads in a Textar or Pagid box. If you want better than OEM pick up some PFC 11 pads from ApexPerformance.
http://www.pelicanparts.com/catalog/..._pg1.htm#item2
As for rotors I use ATE from Pelican Parts. They are the least expensive but they have held up on track for me as well if not better than Zimmerman or Sebro.
http://www.pelicanparts.com/catalog/...pg4.htm#item16
I wish people would stop perpetuating the myth that OEM = OE spec. It's well documented that Porsche will not allow its suppliers to sell parts to OE spec.
(usually the OEM can get away with selling superceded spec parts as well as reject parts)
For example, the Porsche brake rotors for a 944 S2 are visibly and measurably different to the "OEM" parts from Zimmermann.
The cooling fins are a different design and better made. The Porsche rotors are balanced using pressed steel inserts which don't create hotspots on the rotor, unlike Zimmermann's technique of machining the OD. And it looks as though they use a better material/heat treatment because the Porsche rotors last 50% longer than the Zimmermann...
Engine bearings from Porsche are tighter tolerance than from Glyco, the OEM. And does anyone believe that N-spec tires are no different?
</rant>
Cheers,
Mike
#33
Textar and Pagid might be OEM but they are not OE spec. Porsche pads are not just Textar/Pagid spec with Porsche tax added. They are better spec and perform better.
</rant>
Cheers,
Mike
</rant>
Cheers,
Mike
N-spec tires are different than none N-spec but brake pad OE compounds are the same. You do not even have to take my word for it. Go to a Porsche dealer and buy pads. Then check the manufacturer and part number on the pads then cross reference it to aftermarket. You will find the exact same spec pads in the aftermarket. I know because I have done it.
#34
Basic Sponsor
We have the Sebro slotted rotors for 996T with free shipping in the US
https://rennpart.com/carrera/carrera...pgrades-track/
Pagid pads are in stock as well, and pre-bedded in at no extra cost, also with free shipping, as well as stock "Textar" pads at much lower cost then OE.
https://rennpart.com/carrera/carrera...y-replacement/
#35
Which rotor and spacer kit did you wind up with?
#36
Kevin recommended Girodisc 12mm spacers, longer Porsche 997tt caliper bolts and Porsche 997tt rotors from the source with the best price. I called girodisc directly for the spacers.
#37
Threads are aluminum and who last put the bolts in and how many times on/off the calipers have had may get you familiar with Time-sert.
Studs are cheap if you subtract the cost of new bolts.
Confirm torque of ~63 ft. lb
#38
Warning--minispare won't fit over 350mm rotors
I have Girodisc 350mm rotors on my 996TT. I like them a lot but keep in mind the spare tire won't fit over these. If you're planning a cross country road trip you might want to keep this in mind.
#39
I have 350mm Brembo GT kit on my 996 and realized the spare won't fit. I keep it there as it holds up the funk floor and is rumoured to increase frontal impact safety. I was told that the mini-spare from a PCCB equipt car will fit. I have looked and cannot find one so far.
#40
Weighs less too.
#42
I went with the Sebro 350mm 997 TT rotors front and rear, and 12mm caliper spacers. I was planning to refinish the calipers on my car and figured I would refresh the rotors at the same time. I was wanting to upgrade to a large rotor vs stock 996 TT 330mm, and the Girodisc seemed nice, but kind of overkill for me.
I read a lot of good feedback about the Sebro rotors. They are made in Germany and seem to be a worthy replacement. Less $ than OE Porsche too. I think I paid around $750 shipped for a full set of the 350mm Sebro's. Since I was planning to replace the stock discs anyway, upgrading to a larger rotor at the same time seemed like a no brainer.
