New 996TT Crest!
forever the contrarian ....
No.
"The correspondence of a color to a specific wavelength is called spectral color. White and black are excluded from this definition because they do not have specific wavelengths...Black is not defined as a color because it is the absence of light, and therefore color."
Article--> http://education.seattlepi.com/not-l...sics-3426.html
"Forever the contrarian..."
"Black is the darkest color, the result of the absence or complete absorption of light. Like white and grey, it is an achromatic color, literally a color without hue. It is one of the four primary colors in the CMYK color model, along with cyan, yellow, and magenta, used in color printing to produce all the other colors".
Connotation and Denotation are two principal methods of describing the meanings of words.
In philosophy and arguments, the issue is often described as black-and-white, meaning that the issue at hand is dichotomized (having two clear, opposing sides with no middle ground
"When all the wavelengths of the visible light spectrum strike your eye at the same time, white is perceived. The sensation of white is not the result of a single color of light. Rather, the sensation of white is the result of a mixture of two or more colors of light. Thus, visible light - the mix of ROYGBIV - is sometimes referred to as white light. Technically speaking, white is not a color at all - at least not in the sense that there is a light wave with a wavelength that is characteristic of white. Rather, white is the combination of all the colors of the visible light spectrum. If all the wavelengths of the visible light spectrum give the appearance of white, then none of the wavelengths would lead to the appearance of black. Once more, black is not actually a color. Technically speaking, black is merely the absence of the wavelengths of the visible light spectrum. So when you are in a room with no lights and everything around you appears black, it means that there are no wavelengths of visible light striking your eye as you sight at the surroundings."
Link to article http://www.physicsclassroom.com/clas...isible-Spectra
