Clutch Issue I Think?
My car is a 2001 996 turbo 39k miles. I have a issue where the clutch clinks gears on cold starts its hard to put into gear. also on the deceleration in first the car won't come out of gear with the clutch pedal down. It happens sometimes in 2nd but very rarely. When the car is hot like a 1/2hour of driving most of these issues are must less noticeable. She also will grind 2nd gear if the pedal isn't pushed down all the way.
Is this a issue with the clutch or master slave...gearbox, cable wear?
Have you checked the cable alignment/physical connections?
Pentosin levels at both ends?
Bleed clutch
Fresh gear oil
You have some possible issues listed, start with the free to cheap, then evaluate again.
Bleed clutch
Fresh gear oil
First bleed the air out of the slave. Does not use brake fluid. Takes pentosin power steering fluid be careful to keep it away from any rubber. It will eat water hoses. If the clutch resevoir is low check the power steering reservoir too
"It sounds like the clutch is not fully disengaging" is good advice.
If the hydraulics, throw-out bearing, and clutch fork are working as designed, you may have a problem with the pressure plate. At least that was my experience.
check _carefully_ for cracks on the "U" shaped thing in the bell housing - bad design, often breaks
dist. lub is high heat and will work well in the bell housing
I like Swepco for the trans. oil.
* THX much! for helping me kill the horrid screen junk on the web pages!
Might have been the slave, check valve went out pushing pentosin used for power assist to the master cylinder! When the slave goes the pedal engages and disengages at different levels, possibly causing the lack of total clutch release!
