Looking for a high mileage DD. Pitfalls
4th Gear
Hello
New member. I am in the market for a 996 T as a daily driver. I would prefer a higher mileage car that would be priced accordingly. I know that you should buy the best car you can afford but I really do not want to tie up 40-50k on a daily driver.
Question. Any specific problem areas on these cars? This will be my first water cooled Porsche. They seem to be pretty reliable cars. I will try and find one with as much documentation as possible but if I come across a 150k car with no records should I run away or jump in?
Anyone have one for sale?
Thanks in advance for your insight.
Jeff
Jeff
if the car is up to date with maintenance and has had frequent, higher mileage in the last few years, is probably a smart buy
FWIW, low mileage has no benefit to quality, high mileage has nothing against quality...maintenance, care, proactivity
As Rob wrote proper maintenance is key.
I've seen a few with miles at 110K and up under $30K. But they are at low-end dealerships and presumably have zero records.
Considering the cost of some of the things our cars need at various times, I'm gonna echo the above posts.
I tried to use my car as a DD with less than spectacular results. The fact remains that these are old cars and you will get stranded at some point. Unless the maintainance includes recently replaced all rubber, pinned coolant line, etc you're gonna miss a few days at work. Good luck.
Example, with my S430, I needed new lower control arms on both front sides. Mercedes price for parts about $1,200 per side, plus my normal Indy labor of about $800. I took my time and discovered warehouse33auto.com and Jason got the parts for less than half that price. Then I found a shop that installed them for $250. Total cost ~$1,400. had I been forced to go with the initial estimates, it would have been about $3,200. But I was able to drive my old E30 convertible for a couple of months while I sorted through the options.
Hello
Jeff
Jeff
'course, if you are the type of person who likes to jump in and then come out smelling like a rose then maybe you are one of the lucky ones.
If not putting a Turbo right that is wrong can be a very expensive experience.
Even if I came upon a 150K miles 996 Turbo with good service records I'd still give the car a thorough used car check out.
As for problem areas, as the miles accumulate every area can be a problem area. From the spoiler to the headlights.
All you can do is try to find one that has received reasonably good and documented service and there is evidence it was "loved" by its previous owner(s) and this is evident by a stack of invoices accumulated by taking care of things that have come up over the years and miles, things besides services.
Arrange for a 15 mile test ride then turn around and give the car a 15 mile test drive. Spend some time in the car in its natural state and environment: Engine running and the car being driven or you driving the car like you intend to use it.
Afterwards if you still like the car and believe it worth owning arrange for a PPI. Among other things this will have the car in the air so a careful inspection can be made for any leak sign.
4th Gear
Thanks for the input.
KC. I do have several other cars to use. Honestly the Turbo will be used 2-3 times a week for a 80+ mile round trip.
Macster. Thanks for your input.
Jeff
Jeff
I think a 996T is a perfect DD and I don't see anything wrong with looking for a higher mileage one. There's not "that" many issues with these. You said you have back up vehicles so it shouldn't be a problem. Maintenance over miles for sure. Switch to snows for the winter and it's pretty good. I've been doing 140miles round trip 3-4x/week for 6 years now..
That's great, I bet you look forward to going and leaving work.
Not sure when you're looking to buy, but in the next month or two, I will be selling a white 996 turbo with a six speed for about $30k, has about 68k on it. It's not perfect, but overall it's a pretty nice car...
4th Gear
32 Krazy thanks for the offer but I am going to pass on your car at this time.
First off thanks to everyone for there insight.
So the mileage does not scare me as long as the car has been maintained.
Are there certain things that I should look for to be done on the car with over 100k?
Should the Clutch have been done?
I see discussion about pinned coolant lines? Not sure what that is?
Any other major maintenance issue that should have been done by 100K?
