996 Turbo Forum 1999-2005
DIY: Modding front radiator brackets for big tires
Old 03-15-2016, 05:06 PM
James88
James88's Avatar
Originally Posted by Carlo_Carrera
245s fit on my car with no modifications.
I guess every car is a bit different
With 235/40/18 on OZ racing wheels I bent front liner brackets and heat molded liners, created a bit more space but it was still just touching at full lock on right side only. So I'm guessing larger tires will rub on my car.
Old 03-15-2016, 05:26 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,228 Likes on 1,437 Posts
Interesting, are you running stock suspension?
Old 03-15-2016, 06:02 PM
powdrhound
powdrhound's Avatar
Received 1,721 Likes on 1,003 Posts
Originally Posted by Berra
Wow, 275 front...talk about meat!! Could you post pics of that beast? Would love to see how it looks with those tires, and also in general.
I'll post up pics when we get it all set up.
Old 03-15-2016, 06:21 PM
James88
James88's Avatar
I'm on PSS10's at lowest specified height. My rubbing is at the front section of the liner at full lock and only on the right side.
Old 03-15-2016, 06:29 PM
Carlo_Carrera
Got it. The PSS10s change everything.
Old 03-16-2016, 03:54 AM
911mhawk
911mhawk's Avatar
PSS10's here with 245s and no rubbing.
Old 03-16-2016, 04:32 AM
James88
James88's Avatar
That's interesting and I wonder why my right front 235/40/18 tire is touching the front part of the liner.
Old 03-16-2016, 02:13 PM
911mhawk
911mhawk's Avatar
I may not be at the bottom of the height range for the PSS10 so that could be the difference. Mine came with the right look height wise and after replacing lots of pieces with monoball/solid links and adding camber I like the handling so I won't be messing with height until I switch to a remote canister system.
Old 03-16-2016, 06:27 PM
James88
James88's Avatar
Ok, very good. Sounds like you're on top of things.
Old 03-17-2016, 11:42 PM
993GT
993GT's Avatar
I'm sure the 335's do, just tire availability seem to be getting worse/more specific...us 911 owners need to bug the tire companies more for tires that meet load rating needs...
By far the biggest 996 issue is brake bias, esp. at street temps....need 997 or better bias ASAP...wish Cup ABS was CAN/street-ok, if hydraulic bias was 'right' I'd consider just pulling the fuse on stock ABS street/track...PFC pads aren't disc-nice, esp when cold, but they are nice and consistent when 'on'
I think a 255/315 combo with better/997 brake bias will be king for my usage
Originally Posted by powdrhound
With the correct wheels 335s fit without issues but they need to be paired with a larger front to maintain balance. We did trim the sheet metal and the inside of the fender lip slightly near the aft end by the junction of the bumper to ensure clearance at low ride heights. None of this is visible from the outside obviously. Braking will be amazing for sure. I know I'm gonna be going through rotors like crazy with this set up as the Cup ABS already eats rotors at an alarming rate. Ugh...
Old 03-18-2016, 02:49 AM
powdrhound
powdrhound's Avatar
Rob, just throw the 997GT PCCB rear calipers on and the larger 997 master cylinder and call it a day. Problem solved...
Old 03-18-2016, 05:45 AM
993GT
993GT's Avatar
You know it John... Soon as the current 11's are 'gone' back there, it's caliper/MC time
Cheers,
Old 03-18-2016, 02:17 PM
SteveMFr
SteveMFr's Avatar
I snagged a set of 997 Cup calipers - smaller pistons than the street cars. I will have to do some calculations to see what the bias is with the stock 996 rear calipers and with 997 street calipers. I will be running 380mm discs.
As I posted in my build thread, radiator clearance is one of the next issues I have to tackle. I have 19" OZ Ultraleggeras with 235s at the moment and it just fits. But I will likely be moving to 245s and widening the track to take advantage of the additional space I have with the RS flares.
Timing for this thread could not have been better! Thanks Pwdr
Old 03-18-2016, 02:42 PM
powdrhound
powdrhound's Avatar
Steve,
997Cup calipers have the same piston sizes as the 997.2GT3 (380mm) calipers, 28/30/32. The Cup calipers do not have any dust boots. Rears are 34/34.
You will NOT want to run the 7Cup/GT3 calipers with the 996 rear calipers. The 996 calipers are way too small (28/30) with almost 50% less piston area. I tried it several years back. Bias is horrible. You need the 997 rears along with the 997 master cylinder.
Cheers!
Old 03-18-2016, 04:09 PM
SteveMFr
SteveMFr's Avatar
That clears things up a little for me. I was told they are cup calipers by the seller, but I was not completely convinced. When they arrived, the piston sizes matched the cup sizes. They have dust boots, tho, so it seems they are not cup calipers and my doubts are confirmed. Better for me anyway, though, as I want to use the car on the street as well.
Quick Reply: DIY: Modding front radiator brackets for big tires
