Questions regarding 4 piston brembo calipers.
Hello guys.
I am quite new to this topic and have been doing some research, but have not been able to find the answer that I am looking for.
I am looking for Porsche brembo front calipers that I can put over 345x32mm thick brake discs.
I know the 996 runs 28mm thick discs, but I have heard the turbo use 34mm thick ones. What should I be looking for?
How can I see if the caliper is from a turbo or not?
On the attached picture is a m3 with this setup but the 28mm thick ones and that does not work for me
Hope you can help
Hope you can help
