Grind / lock out of 2nd on downshift
Any idea if you have an aftermarket shifter like a B&M? If so, your fore/aft bushings may need to be tightened.
Stock shifter...
I've never had shifter cable issues and thats about all that's left you can *hope* it is given you've reasonably ruled out old trans oil. all else leads to internal issues e.g. synchros/and or ( 2nd ) gear/sycnchro having been rounded, but it didn't pop out(?) it just "ground" upon shifting? so hopefully it is just a cable issue 1st and second ( though third on tracked and seriously driven cars can also give out eventually though that isn't your issue ) are prone to fail over time owing to the design of the triple cone synchros that were implemented for a smoother operability. without going into depth on what often happens to them, and why, hopefully it will either be just a cable adjustment or maybe you just missed a shift while learning the car ( hope not ) but that would be better that the other possibilities. opening the box is fairly labor and cost intensive, relatively speaking.
sometimes just being a new owner of these cars causes issues to surface that were heretofore unknown. or worse, undisclosed ) hopefully that wont be the case. i say *undisclosed* because porsche was unable to identify "2nd gear pop out" in my first 96 t, but they fixed it under warranty. ppi's miss stuff all the time.
in any event, good luck.
as to coolant line pin/weld/epoxy, sure thats a great preventative and there is certainly no reason not to do it in the event your engine is out already, although i am of the opinion ( at 132k+ mostly hard miles ) that if they go? i go in, but not before. unless, ( yes ) engine is already out. then, for sure.
i think you need to ascertain and isolate the conditions under which the "grind" occurs and then act accordingly based upon a diagnosis that has symptoms your tech ( or those of us that have gone thru these things ) could help you to *properly* diagnose. i sure wouldn't open the box on a whim or grind though. its too expensive for a "look see".
Is the type of gear oil used after the PPI mentioned on your invoice?
Unlikely to be a "stock shifter" issue.
How many times as it happened since?
You say 1/2 shift is notchy? Take it to a good shop and let an experienced tech take it for a drive. Could be a bad 2nd gear syncro/dog, or not....
Cheers
Cheers
Alright guys, just dropped off the car in the capable hands of Rick Deman Motorsports, hopefully it won't turn out to be a big deal.
