996 Spoiler Error Code
Yes it working fine manually, but after checking briefly it does not look fully extended. I am going to thoroughly diagnose the issue tomorrow, as I've been tied down with work.
I've collected a ton of data on the factory hydraulic system.
You must be fully extended such that the top microswitch engages. Full extension for a coupe is 2.4", both sides. If the right passenger side is a bit lower, you get a warning. That indicates a fluid leak. If the wing does not fully extend in a certain amount of time, you get a warning. That indicated hydraulic power pack or system issues. If the top microswitch is faulty, they are like a fine Swiss watch inside, you get a warning. Has the system or microswitches been worked on before? Many have I'm finding. I'm seeing all kinds of things, and have a nice collection now of old hydraulic systems in my workshop.
That's why I'm about to launch an all electric replacement kit. Thanks for the "new OEM system" data point on price. I'm coming in less expensive for a better system.
I'm almost there!
I'm almost there!
