Warm weather vs coolant temp
Hi all
On Sunday the weather here was barely 70 degree. I was stuck in stop and go traffic for about an hour. I noticed that the temp gauge was slightly higher than normal. If I have to guess I would say normally is 185 and during a he stop and go 195-200. Just wondering if that's normal?
I drove on an eight hours trip and the temp was death steady at 185 so this kinda threw me for a loop. May be not enough air flow fthru the radiators in the stop and go traffic?
BTW, it is not uncommon for the coolant temp to climb under some conditions. On the freeway on a mild day the coolant temp stays down.
Even driving at 75mph or even faster in AZ in 118F heat the coolant gage needle didn't climb any. Except for the outside temp display I couldn't tell you the out side temp was 70F or 118F. The car was unfazed by the heat. Heck the A/C wasn't even working hard.
But on a mild day if I then switch to driving in town puttering around a shopping center parking lot, the coolant temperature will go up to the point the radiator fans come on.
(If I have the A/C on already, the fans runs all the time and the coolant temperature stays down and steady.)
I've even had the engine idle speed increase. On July 3 2009 I was driving up I-80 towards Nevada (from CA) and with the grade, traffic, and the nearly 90F ambient temperature -- and I had the A/C off -- I noticed the engine idle speed was up some. The DME I guess upped the speed to circulate the coolant more and/or the oil to help control engine temperature.
The engine was running fine and after a bit I just ignored the extra RPMs. Once I got up the top of the grade and speed picked up and I got out of the stop and go the engine idle speed slowed down and everything was back to normal.
I've had the car in hot conditions since, but not in stop and go and high elevation, and the idle speed has never gone up (or down.)
check for radiator fan operation/competency...if all are working, rads might be bad...
used to experience some high 'duty cycle--into traffic' movement...started the aluminum radiator thing with CSF and haven't looked back...no 'overtemp' fluctuations since...
Yeah, CSF is my next stop.
To answer the original question with another data point, my temp. reading on the gage (after warmed up) is always the same regardless of ambient conditions...so I would say yours is problematic.
The temp only crept up during the stop and go traffic. As soon as we were moving it back down to normal, 185.
182 rain sleet or snow or ya got a problem. probably bugs stuck up in your grills lol. sucks but common. on rare occasions i'll see 183 a smidgen over 180. NEVER more.
iirc? 180 is the mark and the needle should always rest just to its right a smidgen. i call that 182 lol
normal given the stop/go except a cpl ticks hi.
Checked mine on an an OBD2 scanner this morning, mine moves about 1/8" from slightly right of 80C to just left of vertical. this movement covers the range 85C (185f) to 95C (203f).
On my Cayenne turbo the range from 69C (156f) to 95C (203f) is covered with no movement of the gauge.
but theoretically any "OAT" coolant and 50/50 distilled water mix would suffice.
as of this thread and our first taste of pre summer heat, i've seen my gauge temps ticking higher also, but only for brief moments in "traffic". as long as it settles back just north of the 180 tick, i'm not concerned.
