coolant pipe failure! SF area repair ideas?
Yes, the dreaded coolant pipe failure has caught up to me, and after only 2 months of ownership, too! Regular street driving, just starting a nice drive up to Alice's Restaurant. A friend was driving my 996tt, I was trailing in his Miata. Quite dramatic to see all the coolant dump and the big plume happen!
I have no desire to re-open the ancient religious battle between pinning and welding. Instead, I'm hoping to find recommendations for San Francisco area shops that have regular experience fixing this, whichever method.
Any ideas? (And yes, Sharkwerks is already on my list to call, but they are a bit far from me.)
And, while we're at it, any recommended towing services?
Sorry bro. Hit me 1 month into ownership too. What ever you decide when they drop the motor do everything's area pump hoses plugs coil packs. Good time for a lot of maintenance.
Here is my list:
Coolant pipe fix
Expansion tank
Water pump
Check valves (I thought there was only one, but there are two)
Oil pressure sending unit
Metal turbo oil feed lines checked
Waste gate vacuum lines
5 bar fuel pressure regulator
Clutch kit
Slave cylinder (found it was leaking a bit with the engine removal. Bad news/good news)
Pressure accumulator
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Endless brake fluid
Coolant
Throttle body seal
Transponder
Coil packs
Solenoid brackets
Engine mounts (RSS)
Trans mount (997 version)
Multi-rib belt
2nd gear detent
Coolant pipe fix
Expansion tank
Water pump
Clutch kit
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Endless brake fluid
Coolant
Throttle body seal
Transponder
Coil packs
Solenoid brackets
Engine mounts (RSS)
Multi-rib belt
2nd gear detent
I suppose I may as well do the 60k major service 7k early, if I'm going to do plugs and coil packs. Water pump and expansion tank sound mandatory based on other threads. Not sure it's worth doing the clutch, however, since mine is fine.
Here is my list: Coolant pipe fix Expansion tank Water pump Check valves (I thought there was only one, but there are two) Oil pressure sending unit Metal turbo oil feed lines checked Waste gate vacuum lines 5 bar fuel pressure regulator Clutch kit Slave cylinder (found it was leaking a bit with the engine removal. Bad news/good news) Pressure accumulator Spark plugs Water hoses Fuel filter Air filter Crankshaft seal Boost pressure test Wastegate adjust Endless brake fluid Coolant Throttle body seal Transponder Coil packs Solenoid brackets Engine mounts (RSS) Trans mount (997 version) Multi-rib belt 2nd gear detent
Yeah, GMG is a wee bit far for me, as it's in So. Cal. :-)
Any experience here with Heyer Performance in Mountain View?
http://heyerperformance.com/
"Our people are extremely experienced experts in the field and their credits include 3 mechanical support stints at Le Mans in factory Porsche teams."
Or Pacific Power Motorsports in Walnut Creek? (h/t to seanl for that recommendation)
Tony Heyer is a great guy and super knowledgeable. I remember speaking to him about this problem and he did not have any specific solution for this. Not sure if you will get the engine repaired like you want. But I am not knocking Tony in any way. He really knows Porsches, his shop is very clean and organized and he is a reputable guy.
Basic Sponsor
If Sharkwerks is booked that far out, here is alternative shop that we recommend to perform this job. They are one of our authorized dealers in the area and the they have our BBi Coolant Pipes in stock. The person to contact there would be Chasem.
SP Automotive Group
1840 National Ave
Hayward, CA 94545
Phone: (510) 782-0188 Email: info@spmsracing.com
- Jerry@BBiAutosport.com
SP Automotive Group
1840 National Ave
Hayward, CA 94545
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
How many miles were on your cars when this happened? Is it mileage dependent or more an age thing?
http://pacificpowermotorsports.com/
I'd have no problem with them dropping my engine out when the time comes...
GT3 player par excellence
it u haven't done it
do
it NOW
u can spin out
u can wrap the head
u can destroy the deck
it will happen. I have a lot of these cars.
it has nothing rondo with mileage
or
age or how u drive
them. it will happen
do
it NOW
u can spin out
u can wrap the head
or
age or how u drive
