Hollow Spoke Valve Stems
Are the metal valve stems typically replaced when new tires are mounted on the stock hollow spoke wheels, or do these last significantly longer than standard rubber stems? If needed, I want to have some stems on hand for the tire shop when I have new tires mounted...
No they are not replaced, though I do keep a couple on hand just in case the tire shop does something and breaks them. Had it happen once and had to wait hours to get one so that is why.
I had a few with worn out rubber seals (at the base) last time I had new tires mounted. Had to get a few new valve stems at the dealer in order to get my tires mounted ( was charged around $15 each). Replacement O-rings were not available separately. Darn it!
I would look over the existing ones carefully and reuse if they look alright. |
Originally Posted by rabbit1445
(Post 10430214)
Not what I want on a car that is capable of going nearly 190MPH. Old tired fatigued tire stems. |
Originally Posted by Macster
(Post 10430264)
Should be if the job is done right.
Originally Posted by NoGaBiker
(Post 10430703)
What's this "nearly" 190mph? :nono:
Hence the " 'nearly' 190mph". Even though I've never exceeded 168mph I still am glad new valve stems were used at the last tire replacement. |
