Constant beep in reverse...
When in reverse I can hear a constant beep and the rear parking sensors don't seems to work. What can cause that ? Bad connection in the rear bumper ? It does my head now!! Thanks for your help.
Mine too, intermittently. Ever get a fix or solution for it? I know when it rains the beep is constant, but mine is constant sometimes and normal others… i.e., just a small beep with I shift into reverse… I'm going to replace the back up light sensor and see if that fixes it… then again, there might be a short in the wiring somewhere...
