Part 2: still having boost issues
So I dropped my car off for service and I'm still having boost isssues. I would say 1 out of every 10 WOT's it seems to break up. I know its not bad gas as the dealer said it would be happening constantly.
I have replaced the fuel pump, spark plugs, coil packs and smoke tested the system. Still having the same problem. The wierdest thing is the car has no check engine lights and is 100% stock.
What is my tech missing? He is now going to pressure test it he said. He's thinking its a vaccum line or something stupid.
Find a hill, slow to 2000 RPM in 3rd gear, and go WOT going up the hill. Note maximum boost and at what RPM you notice any issues with the boost (or with the power delivery). Report back.
Pressure testing it is a really good idea! Of course you want to do it under load,see if it exhibits your problem. You want a constant pressure,no bouncy needle.
How are your actual turbos? Are they leaking any oil?
How many miles on the car?
Any recent work that has been done to it?
Less in 2nd gear, more in 3rd and 4th gears. Starts at about 3k RPM and only on WOT. Happens about 1/10 of the time. Very odd.
How are your wastegates?
Did you check those?
Quote :
' A wastegate is a valve that diverts exhaust gases away from the turbine wheel in a turbocharged engine system. Diversion of exhaust gases regulates the turbine speed, which in turn regulates the rotating speed of the compressor. The primary function of the wastegate is to regulate the maximum boost pressure in turbocharger systems, to protect the engine and the turbocharger. One advantage of installing a remote mount wastegate to a free-float (or non-WG) turbo includes allowance for a smaller A/R turbine housing, resulting in less lag time before the turbo begins to spool and create boost. '
Quote :
I have the car at a Porsche dealership here in NJ, they are super nice and very helpful.
if more boost is present in higher gears(ie in 5th vs 2nd) then it is likely 'weak' wastegates, or less likely but possible vacuum/boost leaks
