04 996 Turbo 2 piece carbon ceramic front rotors?
Does anyone know if its possible to but just the aluminum hats and hardware for the PCCB front rotors? Or is there someone who makes a spacer ring (about 3/32") that can go between the rotor and the hat?
I have a set of GT3 front rotors PCCB flawless condition, but I need the 996 turbo hats for an 04 otherwise these will not fit right.
Another option is to find someone willing to do a flat out exchange?
Any advice or sources?
Are you sure it doesn't fit ? 996TTpccb/996gt2pcccb/996Gt3pccb are normally sharing the same calipers and 350mm rotors front and back.
Don't think you can unscrew the bolts as they are usually corroded inside and the tip of the thread is "squash" from factory. You need to drill them out with a carbide drill. Just been told Porsche do not sale the bolts and lugs for the pccb...not sure if it is true. I need to call them here in UK to find out as one of my front pccb rotor has 2 snaped bolt heads !!! They are rubbish If I may be honest....
