996 Turbo Forum 1999-2005
The Rebuild of a 996 Turbo
Old 07-29-2013, 11:10 AM
  #31
Scott.
Scott.'s Avatar
Originally Posted by 2K3TTMIA
good to see it alive and kicking. how did the fit and finish turn out? the outer painted bits look good also.
drive it often and enjoy.
Thanks! It took a long time (6 months) but they did a great on job and the final cost was around 33k.
Originally Posted by rmc1148
I was just wondering aloud today about your car to my wife (she ignored me as usual lol) I'm glad to see its back together and looking great=mystery solved lol.
Ha! Thanks
Originally Posted by Macster
Looks good.
BTW, I hit a mule deer out near Ely NV with my arctic silver 2003 Turbo just a couple of weeks after buying the car used with just 10K miles on it in June of 2009.
Ouch, glad to hear it's back to normal. I haven't taken it back to the dealership for a paint test but that's a good idea. I'm going to get a 3M clear bra so the track doesn't chip away at the new paint and headlights too.
Originally Posted by NYC996x50
The car looks fantastic! Did you go with 2 layers of clearcoat or 3?
Thanks! Not sure on the layers but they are Porsche certified so hopefully they matched the factory settings. This will be my track toy so I'm guessing the perfect paint won't last long
Old 08-09-2013, 09:09 PM
  #32
joelesmith
joelesmith's Avatar
what shop did the work on your car and would you recommend them?
Old 08-12-2013, 08:08 AM
  #33
Scott.
Scott.'s Avatar
Precision did the body and paint but they sent it over to Sunset Porsche for the complicated stuff (dash removal, etc..). They did a great job but I'm sure it would of been a better experience if insurance wasn't involved.
I do my own work for modifications and maintenance but also use Rothsport Racing for track alignments. Speaking of which, might as well include all of the little stuff that I switched out prior to the track day.
996 GT2 Spec 18" OZs w/ 245/40/18 and 315/30/18 Toyo R888s
996 GT3 Front Calipers
997TT Brembo 2pc Front Rotors
997TT Rear Rotors
Carbotech XP8 Pads
Castrol SPF Fluid
997 GT3 Master Cylinder
997 GT3 Front Ducts
Pwdrhound Custom GT3 Brake Line
PSM Disabled (unplugged at the pump)
Pad Sensors Disabled (re-wired)
RSS Engine Mounts and Rear Toelinks
RSS engine mounts
RSS rear toelinks
Modified brake pad sensors to remove the stupid light
- cut, splice, twist, solder, re-cover and re-install
Old 08-12-2013, 03:23 PM
  #34
PelicanParts.com
Basic Sponsor
PelicanParts.com's Avatar
Looks really good and I bet you're happy to finally get it on the track. What items/fab work had to be done in the body shop, a while ago now but just curious.
Thanks! Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old 08-13-2013, 09:08 AM
  #35
powdrhound
powdrhound's Avatar
Received 1,707 Likes on 995 Posts
Looks great. I'm glad the custom brake line worked out for you. If you track on a regular basis, you might want to consider the GT3 Cup brake ducts instead of the street ducts. You'll get much better cooling. Your brakes will thank you. I'd also install the rear cooling ducts.
Old 09-19-2013, 10:50 AM
  #36
Scott.
Scott.'s Avatar
Ha, bad year for the turbo, check out this recent disaster below. The good news is that I have more GT3 goodies on the car now and a new rear main seal
Porsche LWFW and 996GT3 clutch disc
Sachs motorsports pressure plate 883 308 2999 764:
Part numbers for LWFW conversion, clutch parts, etc..:
Thanks! the entire left side of the car received factory new parts but the door hinges needed some metal work.
Thanks for your help! Yes, the cup ducts are on my list and I also have some SS lines sitting around too..
Old 09-19-2013, 12:31 PM
  #37
rmc1148
rmc1148's Avatar
Looks like you put it back with parts better suited to your needs= hopefully that will be it for a while you deserve a break lol.
Old 09-19-2013, 02:05 PM
  #38
Kevin
Kevin's Avatar
Scawt, can you post the prices for the clutch kit. All the extra hardware was worth it. This will give people an idea as to what the dealership charges for parts and install.
Old 09-19-2013, 03:52 PM
  #39
Scott.
Scott.'s Avatar
Here you go!
Old 09-19-2013, 10:49 PM
  #40
Misplacedyankee
Misplacedyankee's Avatar
Impressive rebuild. Wow. Feel your pain. Clutch too boot. At least you have your track car back in action.
Old 09-20-2013, 01:33 PM
  #41
PAULUNM
PAULUNM's Avatar
Can you provide more info on the Pwdrhound custom brake line?
I'll be upgrading my brakes to 996 GT3 calipers and 997tt rotors, front and rear.
Old 09-21-2013, 02:59 PM
  #42
Kevin
Kevin's Avatar
Please remember that Sachs recommends a 400 mile break in with the clutch.. Normal street driving>no hard launches.. Driving thru city traffic will give you the best results..
How do you like the clutch and the engagement?
Old 09-23-2013, 04:37 PM
  #43
powdrhound
powdrhound's Avatar
The custom brake line allows you to use the 997GT3 brake master cylinder on the 996tt. The 996 MC has a larger 27mm piston vs the 25.4mm on the 996 MC. This will allow you to move more fluid = harder brake pedal. This is pretty much a must if you also upgrade to the much larger 997 rear calipers.
Old 10-03-2013, 08:36 PM
  #44
Scott.
Scott.'s Avatar
Love the LWFW and the responsiveness... I had some weird issues with the clutch pedal only coming up halfway for 24 hours but it magically disappeared and its been 4 days of no issues
On a side note, I finally installed the GMG WC bar in my garage but having a hell of a time putting the bolts in..
Quick Reply: The Rebuild of a 996 Turbo
